01-14-2019, 14:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | A520F FRP Problem [Answered] I Have A520F on the following firmware. Code: A520FXXU7CRL7 Code: Selected AP file: C:\Documents and Settings\user\Desktop\a520f \COMBINATION_FAC_FA60_A520FXXU7ARJ1_FAC7ARJ1 _CL14478682_QB19993759_REV00_user_mid_noship.tar Please put the phone into Download Mode and connect USB cable. To put SM-A520F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.7.6.1 Software version. Regards |
01-14-2019, 14:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Most likely this boot parition isn't compatible with your device. Please, try to use another combination firmware file. |
01-14-2019, 15:20 | #4 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | 1) Flash Combination U7 2) Use OctopusBox - reset FRP ADB 3) Factory reset ( Menu ) 4) Flash Original rom U7 ONLY: Boot + sBoot + Recovery + System + Cache 5) Run ROM and duble Factor reset ( Menu ) 6) Flash all file U7 Original ROM Last edited by huaweinckunlock; 01-14-2019 at 15:27. |
The Following User Says Thank You to huaweinckunlock For This Useful Post: |
01-14-2019, 15:31 | #6 (permalink) | |
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Quote:
You also need to reverse the reset after flashing several files. and only after that unlock will be removed and you can flash the full firmware | |
01-14-2019, 16:21 | #7 (permalink) | |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Quote:
if i flash full combination i get in factory binary mode but cant enable oem unlock | |
01-14-2019, 17:50 | #10 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Code: ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected AP file: C:\Documents and Settings\user\Desktop\a520f \COMBINATION_FAC_FA60_A520FXXU7ARJ1_FAC7ARJ1 _CL14478682_QB19993759_REV00_user_mid_noship.tar Please put the phone into Download Mode and connect USB cable. To put SM-A520F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.7.6.1 Software version. ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: SM-A520F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-A520F Firmware compiled date: Wed Dec 12 16:54:53 KST 2018 PDA version: A520FXXU7CRL7 CSC version: A520FOXA7CRK7 SW version: unknown Android version: 8.0.0 (R16NW) Sales code: BTU Country: UK & IRE HW platform: exynos5 HW Chip: exynos7880 HW Modem: unknown Security patch level: 2018-12-01 Warranty Void: 0 Codename: a5y17ltexx Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.7.6.1 Software version. |
02-27-2019, 17:44 | #12 (permalink) | |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | Quote:
I can confirm this solution works. I solved one A520F FRP today When flashing original firmware, flash HOME_CSC... Thx for solution . | |
The Following 2 Users Say Thank You to Spalato For This Useful Post: |
