07-16-2017, 09:02 | #16 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2253202 Status: Offline Thanks Meter: 32 | i realise there is no way am gonna fix this phone i really appriciate for your help brother |
07-16-2017, 14:50 | #19 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | I wrote to you that you had to do the original firmware firmware flash even odin enough to remember the kind of original stock firmware you had before you made the flash of other firmware, using smartswtich in normal emergency mode that makes you the firmware flash original |
07-16-2017, 17:35 | #21 (permalink) | |
Member: 2253202 Status: Offline Thanks Meter: 32 | Quote:
07-16-2017, 17:41 | #22 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | You remember the original android 4.4 firmware that you had before making the various flashes of other firmware that you should replace or try to make root with cf autoroot if your phone is locked if you can put it in dowload mode and make the root should start again |
07-16-2017, 23:33 | #23 (permalink) | |
07-17-2017, 07:54 | #24 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please perform "Reset MSL" operation, then try to make "Write Cert" again. Step by step description of how to write a Cert file is available in phone Software manual ("Help" button in Software). |
07-17-2017, 09:02 | #26 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If IMEI is exactly "null", not 0049..., /01, etc - You need to reflash the phone with different firmwares one by one. When IMEI will have default (0049...), or any other value, except null - perform "Reset MSL" and "Write Cert" operation. If after writing of different firmwares problem will remain the same - it can be a HW problem. |
07-17-2017, 10:37 | #27 (permalink) | |
i tried to reset msl i tried the cert file all failed Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-A700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: absent Codename: a7altexx Checking Root: Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: absent Codename: a7altexx Checking Root: Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: not ready Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A700F-Unknown17-07-2017_11-26-14-.asec file Deactivating MSL... Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700F Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_ 356559060365017.cert Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: absent Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Reading info, please wait... Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: unknown Security patch level: 2016-09-01 SIM 1 status: not ready Codename: a7altexx Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: unknown Security patch level: 2016-09-01 SIM 1 status: not ready Codename: a7altexx Rebooting phone in Download Mode... Phone successfully rebooted in Download Mode. Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_ 356559060365017.cert Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: unknown Security patch level: 2016-09-01 SIM 1 status: not ready Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Writing Certificate failed Performed by 2.5.6 Software version. Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_ 356559060365017.cert Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: unknown Security patch level: 2016-09-01 SIM 1 status: not ready Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Writing Certificate failed Performed by 2.5.6 Software version. | |
07-17-2017, 11:15 | #28 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If phone IMEI remains null after writing of a firmware - You should try to write another firmware. Also, this indicates that modem part of the phone is damaged: Quote:
07-17-2017, 13:39 | #30 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | As you wrote the Octopus support and as I wrote you earlier you have to write the different firmware if even with that you can easy you have hardware problems on the phone and you have no alternative not being a software problem |
