Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 07-15-2017, 11:43   #1 (permalink)
Member: 2253202
Thanks Meter: 2
Post a700f null null
I have Android 5 and i am waiting for imei null help
Welcome to Octoplus/Octopus Box Samsung software version 2.5.6
To connect SM-A700F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Press "Read Info" in software.
Selected firmware file: a700fxxu2boh1_a700fxef2boh1_xef_android_
5.0.2.oct
Please put the phone into Download Mode and connect USB cable.
To put SM-A700F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing BOOTLOADER section...
BOOTLOADER section has been written successfully.
Writing BOOT section...
BOOT section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing RADIO section...
RADIO section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Firmware writing successfully completed.
Performed by 2.5.6 Software version.
Platform: Samsung Android
Selected port: COM12
Selected model: SM-A700F
Operation cancelled!
Operation was canceled
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Rebooting phone failed.
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: SM-A700F
Firmware compiled date: Mon Aug 24 20:51:32 KST 2015
PDA version: A700FXXU2BOH1
CSC version: A700FXEF2BOH1
SW version: A700FXXU2BOH1
Phone SN: RF1D45EJGGR
Android version: 5.0.2 (LRX22G)
Sales code: XEF
Country: France
HW platform: exynos5
HW Chip: exynos5430
HW Modem: DB7450R
SIM 1 status: absent
Codename: a7altexx
Rebooting phone in Download Mode...
Phone successfully rebooted in Download Mode.
Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_
356559060365017.cert
Sales code: XEF
Country: France
HW Chip: exynos5430
HW Modem: DB7450R
Codename: a7altexx
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Executing exploit...
Writing Certificate failed
Sales code: XEF
Country: France
HW Chip: exynos5430
HW Modem: DB7450R
SIM 1 status: not ready
Codename: a7altexx
Checking Root:
Phone is Rooted.
Old 07-15-2017, 12:52   #2 (permalink)
Member: 2613252
Thanks Meter: 64
Hello try to do repair efs the code imei must return by default and when it's at 35000000006 try rewrite certificate or use imei repair and then repair network making patch
Old 07-15-2017, 19:53   #3 (permalink)
Member: 2253202
Thanks Meter: 2
i tried to efs but it hangs on samsung logo
please help me out sir i have been trying to find solution for a week now but no luck
Old 07-15-2017, 20:24   #4 (permalink)
Member: 2613252
Thanks Meter: 64
By accident you did the downgrade by making the flash from android 6.0.1 to adroid 5.0.2?
If you do repairs imei from the program you hang the phone on the logo?
Repeat to do the flash of the firmware stock you have to understand if the code imei you have already given it with imei null or if doing the flash of the firmware you disappeared
Old 07-15-2017, 20:41   #5 (permalink)
Member: 2253202
Thanks Meter: 2
the phone did have the android 4 but after writing the certfile it hang on logo and i did flash it with android 5 bcoz if i flash it android 4 it still hang on a logo so i havent tried the android 6 do think if i flash it with 6.0 or smart switch will i get rid of the imei null
Old 07-15-2017, 20:43   #6 (permalink)
Member: 2613252
Thanks Meter: 64
You have to do the original firmware flash that had the phone before the flash before the flash you did and see if you system
Old 07-15-2017, 20:48   #7 (permalink)
Member: 2613252
Thanks Meter: 64
Doing the flash to 6.0.1 does not let you write the cert file because of the new security, you have to understand that original signing had the phone before you did it upgrading and changed the cert of what country it was
Old 07-15-2017, 20:49   #8 (permalink)
Member: 2253202
Thanks Meter: 2
the phone had android 4 before even flash it or tried to write the cert file so shud i flash it again......... the phone will hangs on the logo again
Old 07-15-2017, 20:55   #9 (permalink)
Member: 2613252
Thanks Meter: 64
Did you check the binary revision of the firmware that you did the flash?
Old 07-15-2017, 21:01   #10 (permalink)
Member: 2253202
Thanks Meter: 2
no i didnt i thought i shud flashed it with any version of 4.4
Old 07-15-2017, 21:04   #11 (permalink)
Member: 2613252
Thanks Meter: 64
I find it strange that writing the cert file on android 4.4 the phone goes in fixed logo, usually happens when you are wrong to write the incompatible firmware of the same country or with the different binary revision
Old 07-15-2017, 21:08   #12 (permalink)
Member: 2253202
Thanks Meter: 2
i have the same issue with j5 prime both have same issue but j5 dont hang on logo
Old 07-15-2017, 21:10   #13 (permalink)
Member: 2613252
Thanks Meter: 64
You have two solutions try to do wipe security and see if the imei code comes back to default to rewrite the cert file if it does not work, then back up the security and write it down to see if the imei goes to default
Old 07-15-2017, 21:21   #14 (permalink)
Member: 2253202
Thanks Meter: 2
one problem if click the repair secutity/wipe security nothing happens it like not functining
Old 07-15-2017, 21:25   #15 (permalink)
Member: 2613252
Thanks Meter: 64
Back up your security and try writing it
Page generated in 0.38944 seconds with 7 queries
