07-17-2017, 13:49 | #32 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | However to write the cert you should have imei in default at 049 and the modem part is correct and not unknown as wrote octopus team to write cert Try and see what result you have |
07-17-2017, 14:09 | #33 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If phone has generic "350050500009692" IMEI - yes, at this point You can try to make "Reset MSL", then "Write Cert" operations again. |
07-17-2017, 14:10 | #34 (permalink) | |
Freak Poster Join Date: Sep 2014
Member: 2253202 Status: Offline Thanks Meter: 32 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-A700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: absent Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A700F-Unknown17-07-2017_14-56-22-.asec file Deactivating MSL... Operation was failed! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_ 356559060365017.cert Detected phone model: SM-A700F Firmware compiled date: Thu Sep 1 12:39:18 KST 2016 PDA version: A700FXXU2BPH4 CSC version: A700FTPD2BPH4 SW version: A700FXXU2BPH4 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: TPD Country: The Netherlands HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R Security patch level: 2016-09-01 SIM 1 status: absent Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.6 Software version. ok i have able to write the cert file n i got the imei now is 356559060365017 but no network still emergence call | |
07-17-2017, 14:24 | #35 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Unfortunately with the firmware you have of android 6.0.1 and the September security patch level does not make you write and you need to do the downgrade try to write the patch imei repair and repair network to see t might also be the imei code in black list trying to write another certificate Last edited by Octopus box; 07-17-2017 at 15:01. |
07-17-2017, 15:02 | #36 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What is the status of IMEI Certi in *#0011# menu? If it is PASS/OK - Cert file was written correctly. Problem with network can occur if IMEI of Cert file is blacklisted by local providers. |
07-17-2017, 16:13 | #37 (permalink) | |
----------------------------------------------------------------------------------- To connect SM-A700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A700F Firmware compiled date: Thu Feb 12 22:56:11 KST 2015 PDA version: A700FXXU2AOB2 CSC version: A700FDBT2AOA2 SW version: A700FXXU2AOB4 Phone IMEI: 356559060365017 Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Sales code: DBT Country: Germany HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R SIM 1 status: absent Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A700F-Unknown17-07-2017_17-02-31-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! MSL reset successfully. Please, restart the phone to apply changes Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-A700F Selected file: C:\Users\DJ BIGGIE\Desktop\cert-sm-a700f_rf8g301qe8f_ 356559060365017.cert Detected phone model: SM-A700F Firmware compiled date: Thu Feb 12 22:56:11 KST 2015 PDA version: A700FXXU2AOB2 CSC version: A700FDBT2AOA2 SW version: A700FXXU2AOB4 Phone IMEI: 356559060365017 Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Sales code: DBT Country: Germany HW platform: exynos5 HW Chip: exynos5430 HW Modem: DB7450R SIM 1 status: absent Codename: a7altexx Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.6 Software version. i did what u ask me And repeat the cert file still no service any other suggestion | |
07-17-2017, 16:14 | #38 (permalink) | |
07-18-2017, 07:37 | #39 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to write another Cert file. If problem will remain the same - upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
