01-17-2022, 14:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | A730f flash failed after change emmc [Answered] on download mode kg state : checking custom binary (recovery) blocked due to remaining installment balance Code: Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\17-01-2022_07-40-24.log" created (17/01/2022 07:40:24). INFO : 17/01/2022 07:40:49 > Set up system language English (file: English.ini) INFO : 17/01/2022 07:40:49 > Welcome to Octoplus Samsung Tool version 3.0.7 INFO : 17/01/2022 07:40:49 > Card S/N : 0002359C INFO : 17/01/2022 07:41:11 > ----------------------------------------------------------------------------------- INFO : 17/01/2022 07:41:17 > Work ID: 00000000021EFEA4 INFO : 17/01/2022 07:41:18 > Platform: Samsung Android INFO : 17/01/2022 07:41:18 > Selected port: COM19 INFO : 17/01/2022 07:41:18 > Selected model: SM-A730F INFO : 17/01/2022 07:41:19 > Operation: KnoxGuard Unlock ERROR : 17/01/2022 07:41:19 > Proper android device not found. Make sure that "USB debug" option on the device is turned on. ERROR : 17/01/2022 07:41:19 > Operation was failed! INFO : 17/01/2022 07:41:19 > Performed by 3.0.7 Software version. INFO : 17/01/2022 07:43:46 > Selected BOOT file: E:\SAMSUNG\SM-A730F\BL_A730FXXU7CUI2_CL22376662_QB43516317_REV00_user_low_ship.tar.md5 INFO : 17/01/2022 07:43:47 > Selected AP file: E:\SAMSUNG\SM-A730F\AP_A730FXXU7CUI2_CL22376662_QB43516317_REV00_user_low_ship_meta_OS9.tar.md5 INFO : 17/01/2022 07:43:47 > Selected CP file: E:\SAMSUNG\SM-A730F\CP_A730FXXU7CUI1_CP20271349_CL22376662_QB43224764_REV00_user_low_ship.tar.md5 INFO : 17/01/2022 07:43:47 > Selected CSC file: E:\SAMSUNG\SM-A730F\CSC_OLE_A730FOLE7CUI2_CL22575529_QB43697769_REV00_user_low_ship.tar.md5 WARN : 17/01/2022 07:43:48 > Please put the phone into Download Mode and connect USB cable. WARN : 17/01/2022 07:43:48 > To put SM-A730F into Download Mode, You have to perform the following steps: WARN : 17/01/2022 07:43:48 > 1. Press and hold "Volume-" + "Volume+" + "Power ON" keys. WARN : 17/01/2022 07:43:48 > 2. When phone turns on, press "Volume+" key. INFO : 17/01/2022 07:43:48 > Found phone on WARN : 17/01/2022 07:43:48 > Advanced mode! INFO : 17/01/2022 07:43:52 > Firmware write started. INFO : 17/01/2022 07:43:52 > Writing BOOTLOADER section... INFO : 17/01/2022 07:43:52 > BOOTLOADER section has been written successfully. INFO : 17/01/2022 07:43:52 > Writing PARAM section... INFO : 17/01/2022 07:43:52 > PARAM section has been written successfully. INFO : 17/01/2022 07:43:52 > Writing CM section... INFO : 17/01/2022 07:43:53 > CM section has been written successfully. INFO : 17/01/2022 07:43:53 > Writing BOOT section... INFO : 17/01/2022 07:43:54 > BOOT section has been written successfully. INFO : 17/01/2022 07:43:54 > Writing RECOVERY section... INFO : 17/01/2022 07:43:55 > RECOVERY section has been written successfully. INFO : 17/01/2022 07:43:56 > Writing SYSTEM section... ERROR : 17/01/2022 07:44:52 > Writing Firmware Failed INFO : 17/01/2022 07:44:52 > Performed by 3.0.7 Software version. |
01-17-2022, 16:06 | #4 (permalink) |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | after use other dump , now flash failed secure check fail (radio) Code: Selected BOOT file: E:\SAMSUNG\SM-A730F\BL_A730FXXU7CUI2_CL22376662_QB43516317_REV00_user_low_ship.tar.md5 Selected AP file: E:\SAMSUNG\SM-A730F\AP_A730FXXU7CUI2_CL22376662_QB43516317_REV00_user_low_ship_meta_OS9.tar.md5 Selected CP file: E:\SAMSUNG\SM-A730F\CP_A730FXXU7CUI1_CP20271349_CL22376662_QB43224764_REV00_user_low_ship.tar.md5 Selected CSC file: E:\SAMSUNG\SM-A730F\CSC_OLE_A730FOLE7CUI2_CL22575529_QB43697769_REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A730F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Volume+" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing Firmware Failed Performed by 3.0.7 Software version. |
