07-27-2017, 13:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | A800f frp unsucessful handset version A800FXXU1BQE2/A800FODD1BQF2/A800FXXU1BQF4/A800FXXU1BQE2 octopus logs Code: Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-A800F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A800F To put SM-A800F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.5.6 Software version. |
07-27-2017, 13:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with removal of FRP lock can occur if phone has one of newer firmwares. To remove FRP lock You can try to write sboot.img partition of older by release date firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
07-27-2017, 13:30 | #3 (permalink) |
Member: 116314 Status: Offline Thanks Meter: 147 | handset software information is provided in my post. it is the latest build available so far. if it is safe to write sboot of android 5.1 to this firmware. combination available at support is a800fxxu1aoj2 fa5.1 |
