04-10-2017, 11:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2016 Location: greece
Member: 2666324 Status: Offline Thanks Meter: 8 | After flashing A310F wifi issue Sent from my iPhone using Tapatalk |
04-10-2017, 12:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please post here full Software logs of performed operations. Also, what exactly You mean by "wifi issue"? What was initial state of the phone and why did You decide to reflash it? |
04-10-2017, 12:13 | #3 (permalink) | |
Member: 2666324 Status: Offline Thanks Meter: 8 | Quote:
Reflash because Mobile Speed working Slowly and in Flash no probblam complate flash but After flash Wifi not working Sent from my iPhone using Tapatalk | |
04-10-2017, 13:10 | #5 (permalink) | |
Selected AP file: F:\A310FXXU2BQA3_A310FPLS2BQA3 _A310FXXU2BQA3_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A310F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing CM section... CM section has been written successfully. Writing HIDDEN section... Writing Firmware Failed Performed by 2.5.1 Software version. Selected firmware file: A310FXXU2BPH8_A310FOXA2BPH8 _DBT_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-A310F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RADIO section... RADIO section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.5.1 Software version. | |
