02-18-2018, 15:53 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | again imei null [Answered] ----------------------------------------------------------------------------------- To connect SM-A300H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N900 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N900 Detected phone model: SM-N900 Firmware compiled date: Sun Dec 28 00:53:11 KST 2014 PDA version: N900XXUEBNL8 CSC version: N900OXAEBNL8 SW version: unknown Phone SN: 00000000000 Android version: 5.0 (LRX21V) Sales code: XEO Country: Poland HW platform: exynos5 HW Chip: exynos5420 HW Modem: unknown SIM 1 status: not ready Codename: ha3gxx Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.6.3 Software version. |
02-19-2018, 09:00 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
