Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-17-2012, 06:58   #1 (permalink)
Member: 678773
Anycall W270 to W2700 help
How to convert this model? w270 to w2700
unlock okey but still not working i think the unit does not support sim card only 3g sim or usimcard thats why i want to flash it with w2700
when i flash it with w2700 it shows this error
Platform: Samsung Anycall
Selected port: COM69
Selected model: SCH-W270
Mode: Normal
Phone model: SCH-W270
Firmware compiled date: Mar 06 2007
Firmware compiled time: 23:00:00
Firmware released date: Dec 28 2009
Firmware released time: 05:08:34
Phone IMEI: 354903-01-256721-7
Bluetooth MAC: 00:12:47:01:23:45
SW Version: M6275B-KMRZ-3.2.7133
Creating NVM backup
Reading NVM done!
Switching to emergency mode...
No diagnostic ports found!
Connecting to phone on COM69
Detected phone model: SCH-W270
Mode: Emergency
File has been created for a different phone model.
Old 08-17-2012, 07:32   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
I You wont to flash your SCH-W270 to SPH-W2700, please select SPH-W2700 in phone model list and firmware for this model, put your phone in Emergency Mode, and press Write Firmware button.
Old 08-17-2012, 07:49   #3 (permalink)
Member: 678773
i already did that but same error
Old 08-17-2012, 08:04   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please, try to Repair NVM and make Factory Reset.
Old 08-17-2012, 09:49   #5 (permalink)
Member: 678773
i check manualy select in port settings ang select w2700 and successfully flash the phone after flashing cant boot phone in normal mode even if it is in normal mode it detects in emergency mode cant try to repair nvm and factory settings always show this error
Selected port: COM71
Selected model: SPH-W2700
Mode: Emergency
NVM can’t be repaired for SPH-W2700 phone in emergency mode
Old 08-17-2012, 10:12   #6 (permalink)
Member: 678773
problem solve thnx for the attention
this what i did select manualy on port setting select SPH-W2700 load firmware flash after flashing phone wont restart u need to power on manualy then select the correct port on port settings then repair NVM after that u need reboot phone manualy then identify the phone u will incorect imei so u will need to fix the ime write the new imei for tha phone then tick fix imei again and again reboot phone manualy then unlock!
now my w270 fully working with local sim thnx for the attention sir
Old 08-17-2012, 10:14   #7 (permalink)
Member: 678773
here is the full logs hope it helps
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM71
Mode: Emergency
Mode: Emergency
Mode: Emergency
Selected firmware file: SCH-W270_CL28.oct
Mode: Emergency
Writing boot section...
Port is busy
Firmware writing failed on block #0
Selected action can’t be performed
Selected port: COM54
Mode: Normal
Phone model: SPH-W2700
Warning: Selected model (SCH-W270) differs from detected one (SPH-W2700)!
Firmware compiled date: Nov 15 2006
Firmware compiled time: 11:00:00
Firmware released date: Dec 21 2009
Firmware released time: 11:52:41
Incorrect IMEI
Bluetooth MAC: 00:00:00:00:00:00
User code is set up. Code: 0000
Creating NVM backup
NVM reading process failed
Connecting to phone on COM12
Phone connection failed
Can't switch to emergency mode
Mode: Normal
Incorrect IMEI
Mode: Normal
Incorrect IMEI
Creating NVM backup
Reading NVM done!
Repairing NVM for SPH-W2700 phone...
NVM repair completed successfully
Please, restart phone to apply changes
Mode: Normal
Incorrect IMEI
Mode: Normal
Incorrect IMEI
Mode: Normal
Incorrect IMEI
Unlocking phone...
This phone can't switch to emergency mode automaticaly, please switch it manualy. Reconect battery. Press and hold "4+Power". After this repeat operation.
Phone unlocking failed
Mode: Normal
Incorrect IMEI
Mode: Normal
Incorrect IMEI
Mode: Normal
Old IMEI: 004400-15-202000-0
New IMEI: 004400-15-202000-0
Please, enter new IMEI
Mode: Normal
Incorrect IMEI
Mode: Normal
Mode: Normal
New IMEI: 356946-03-591649-7
Writing new phone IMEI...
New IMEI successfully written. Please restart phone. If phone IMEI stays without changes after restart, provide hard reset for phone and write IMEI once again.
Mode: Normal
Phone IMEI: 356946-03-591649-7
Mode: Normal
Mode: Normal
Unlocking phone...
Detected phone model: SPH-W2700
Mode: Emergency
Mode: Emergency
Unlocking phone...
Detecting firmware type
Searching for signatures...
Reading NAND...
Writing NAND
Phone is successfully unlocked
Mode: Normal
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.68542 seconds with 11 queries
