04-09-2015, 05:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | b 360 e unable to unlock Here are the error logs. Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect GT-S5360 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Connecting canceled. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Connecting canceled. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- To connect SM-G360H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B310E Selected port: USB To connect SM-B310E, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B310E Selected port: USB To connect SM-B310E, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM1 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed Pls guide Regds Narendra Singh |
04-09-2015, 07:35 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Try to re-install these drivers (https://drive.google.com/file/d/0B_k...ew?usp=sharing), re-boot the PC and try again. |
01-27-2016, 14:09 | #4 (permalink) |
Freak Poster Join Date: Mar 2010 Location: hydrabad sindh
Member: 1266092 Status: Offline Sonork: love Thanks Meter: 17 | To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Unlocking phone. This can take some time. Please wait... Unlocking phone... Reading NV section section... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-B360E_27-01-2016_18-01-20-.nv file Phone unlocking failed |
01-27-2016, 14:29 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please manually uninstall current drivers for the phone and install required drivers: http://octopusbox.com/files/drivers/...ile_Phones.exe http://octoplusbox.com/files/drivers/SCIUSB2SERIAL.zip http://octoplusbox.com/files/drivers...iver%20x86.zip After installation restart PC and try to perform the operation again. |
