11-14-2014, 21:36 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | B7722 Writing Firmware Failed PHONE DEAD To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: GT-B7722JP.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-B7722 Selected port: USB Please reconnect the battery, press "Volume-" + "Lock *" buttons and connect USB cable Connecting... Phone found. Chipset version : 22 SCROM version : 36 Sending loaders... Preloader send successfully Conecting to pipes... Successfully conecte to pipes. Writing firmware... Erasing block... Block erase successfully. Writing partition IMAGE ... Writing partition LOWMODE ... Writing Firmware Failed Selected firmware file: B7722DDJH6_ODDJH6.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-B7722 Selected port: USB Please reconnect the battery, press "Volume-" + "Lock *" buttons and connect USB cable Connecting... Phone found. Chipset version : 22 SCROM version : 36 Sending loaders... Preloader send successfully Conecting to pipes... Successfully conecte to pipes. Writing firmware... Erasing block... Block erase successfully. Writing partition IMAGE ... Writing partition LOWMODE ... Writing Firmware Failed |
11-14-2014, 21:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please fully charge phone's battery (with external charger) and try to perform "Write Firmware" operation again. |
11-15-2014, 07:50 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Close the Software. 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Install the latest Software version (Software). 4. Run the Software. 5. Fully charge phone's battery by using external charger. 6. Take out SIM card from the phone. 7. Try to write another firmware from the Support Area. 8. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research, where can be the problem with your device. |
