04-18-2016, 04:37 | #1 (permalink) |
Insane Poster Join Date: Aug 2013
Member: 2009999 Status: Offline Thanks Meter: 4 | brenton ----------------------------------------------------------------------------------- To connect SM-G920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G920W8 Port is busy Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Port is busy No diagnostic ports found! Connecting to phone on COM5 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: CANADA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: CANADA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown17-04-2016_23-09-40-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Read codes failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: CANADA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown17-04-2016_23-14-57-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Read codes failed Performed by 2.2.4 software version |
04-18-2016, 10:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please remove SIM card from the phone, then try to perform "Read Codes" operation again. If problem will remain, please do the next: 1. Reflash the phone. 2. Root the phone with CF Auto Root. 3. Repeat "Read Codes'' operation. Post here the result. |
04-26-2016, 00:07 | #3 (permalink) |
Member: 2009999 Status: Offline Thanks Meter: 4 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect SM-G920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G920W8 Selected file: C:\Program Files (x86)\Octoplus\Octoplus_Samsung\cert- sm-g920w8_357558062432147.cert Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown25-04-2016_18-57-04-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Executing exploit failed Writing Certificate failed Performed by 2.2.5 software version |
04-26-2016, 10:41 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
04-26-2016, 11:53 | #5 (permalink) |
Member: 2009999 Status: Offline Thanks Meter: 4 | this is the link 26-04-2016_06-36-32 - Download - 4shared - Brenton Barnes |
04-26-2016, 12:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please also upload Security backup of the phone and 26-04-2016_06-36-32.logx file. Post here download link these 2 files. |
04-29-2016, 11:45 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We are researching the problem and will inform You about possible solution. |
05-12-2016, 14:48 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please insert any SIM card into the phone and check whether signal bars appear in upper-top corner of phone screen. Also, what IMEI has the phone at the moment? |
05-12-2016, 15:30 | #12 (permalink) |
Member: 2009999 Status: Offline Thanks Meter: 4 | it has full bars but unable to connect to network also i notice im unable to check imei from dial screen and no secret codes that i enter will not work either. also read codes direct unlock writing certs all exploits fails |
05-12-2016, 16:27 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please try to make "Repair EFS", then repeat "Unlock"/"Read Codes" operation. Post here result and full Software log of your actions. |
05-12-2016, 17:20 | #14 (permalink) |
Member: 2009999 Status: Offline Thanks Meter: 4 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect SM-G920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 To put SM-G920W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown12-05-2016_12-01-10-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Read codes failed Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown12-05-2016_12-05-59-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920W8 Selected file: C:\Program Files (x86)\Octoplus\Octoplus_Samsung\EFS \cert-sm-g920w8_357558062432147.cert Detected phone model: SM-G920W8 Firmware compiled date: Fri Mar 18 21:40:29 KST 2016 PDA version: G920W8VLU3CPC5 CSC version: G920W8OYA3CPC5 SW version: G920W8VLU3CPC5 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920W8-Unknown12-05-2016_12-11-38-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Executing exploit failed Writing Certificate failed Performed by 2.2.5 software version |
