11-23-2014, 03:24 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | C101 Android 4.4.2 is Supported ? I need to unlock and imei repair on C101 but with Android 4.4.2 Is supported this version because the firmware on the support area is 4.2.2 Many thanks |
11-23-2014, 08:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We didn't test on the devices with firmwares with Android 4.4.2. We will test and release the solution in one of the following Software updates. |
11-25-2014, 12:08 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared and sent You test Software version to PM. Please root the device, read EFS, security and Certificate, then try to make Unlock and Repair IMEI. Note, currently You can only write one of the service's IMEIs from the Software list or write IMEI from the Certificate. Currently is not possible to write any IMEI, which You want, and to get active network. |
11-26-2014, 08:26 | #5 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote:
I test this procedure but cant make Root on this sw version. I tryed with Kingo and vRoot but I cant. This is the Logs Welcome to Octoplus/Octopus Box Samsung software version 1.7.6 ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-C101 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-C101 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 359xxxxxxxxxxxx Phone SN: CN1F500AJWX Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Reading Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-C101 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-C101 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 359xxxxxxxxxxxx Phone SN: CN1F500AJWX Android version: 4.4.2 (KOT49H) Reading EFS, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Reading EFS failed. I read that the phone need this version for root, its really ? C101XXUBNF4_C101SERBNF4_SER Do you tested root with 4.4.2 ? br, | |
11-27-2014, 07:13 | #8 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote: Here is a full log. Welcome to Octoplus/Octopus Box Samsung software version 1.7.6 ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-C101 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 3593xxxxxxxxxxx Phone SN: CN1F5xxxxxx Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Exploit has been executed successfully Phone will restart now Certificate read successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-C101 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 3593xxxxxxxxxxx Phone SN: CN1F5xxxxxx Android version: 4.4.2 (KOT49H) Reading EFS, please wait... EFS read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 3593xxxxxxxxxxxxx Phone SN: CN1F5xxxxxx Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Security read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Fri Aug 29 03:30:53 KST 2014 PDA version: C101UBUBNH2 CSC version: C101UUBBNH2 SW version: C101UBUBNF4 Phone IMEI: 3593xxxxxxxxxxx Phone SN: CN1F5xxxxxx Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Archivos de programa\Octoplus \Octoplus_Samsung\BACKUP\Security-SM-C101-Unknown27-11-2014_ 03-03-49-.asec file Cheking security type... Old security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 3593xx-05-xxxxxx-1 New IMEI: 356xxx-05-xxxxxx-6 Repairing IMEI ... Network is successfully repaired Phone will restart now IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Thank you Very Much ! Best regards, | |
11-27-2014, 07:30 | #9 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Do you have any Certificate file for this C101 please ? I test because after minutes lost signal and go to Emergency Calls only. |
01-16-2015, 20:36 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Cert file for SM-C101 is available in Support Area, in "Samsung/FOR UNLOCK AND REPAIR/Certificates" folder. To enter Support Area, press "Go to support" button in Software. |
