02-26-2016, 23:51 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: ARGENTINA
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | Can't connect J700m I need unlock and write cert. Please help! B. R. SEBAELPOTRO! Code: Bienvenido en Octoplus/Octopus Box Samsung software versión 2.2.1 ----------------------------------------------------------------------------------- To connect SM-J700M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-J700M ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM1033 Modo: Emergencia La conexión con el teléfono falló ¡Puertos diagnósticos no encontrados! Performed by 2.2.1 software version |
02-27-2016, 12:20 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. To connect SM-J700M phone You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button.] 10. Connect the phone directly to PC. 11. Try to perform "Read Info" operation from "Main" tab of the Software on different COM ports, with enabled "Manual" select option. Unfortunately "Write Cert" operation is not supported for SM-J700M at the moment. |
