03-16-2016, 02:58 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2515499 Status: Offline Thanks Meter: 0 | Can't find diagnostic ports can anyone offer any advice on "diagnostic ports not found"? I've tried everything I think... usb debugging is on... when I connect the phone normally to the computer and press read I get the phone info and imei but when I connect it to the octopus box I get diagnostic ports not found, phone not found any suggeswtions? |
03-16-2016, 13:05 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To connect SM-N910G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Connect the phone directly to PC. 11. Press "Read Info" on Main tab of the Software. Try to perform the operation on different COM ports with enabled "Manual select" option. Last edited by Octopus box; 03-16-2016 at 13:18. |
03-16-2016, 14:02 | #9 (permalink) |
Member: 2515499 Status: Offline Thanks Meter: 0 | i've done all of that, i can read the info when i connect the phone to the computer directly but when i cpnnect the phone to the micro usb of the octopus box to do an imei repair i get that message and the repair part is not accessible and wont let me enter or check any boxes? |
03-16-2016, 17:35 | #11 (permalink) |
Freak Poster Join Date: May 2014 Location: from JORD . work in usa .
Member: 2179929 Status: Offline Thanks Meter: 34 | you have to enable Cp login from recovery mode . go to recovery mode scroll down to cp login enable press the power button . that's all |
The Following User Says Thank You to r.o0y For This Useful Post: |
