05-15-2016, 11:21 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Palestine - Nublus
Member: 431775 Status: Offline Thanks Meter: 94 | can't unlock FRP j700h Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-J700H To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version Selected firmware file: J700HXXU1AOK5_J700HOJV1AOK6 _TUN_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.4 software version are there any way to fix ? Last edited by Octopus box; 05-16-2016 at 10:53. |
05-16-2016, 10:55 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Have You tried to perform "Reset FRP/Reactivation/EE" operation after an attempt to write a firmware? What was the result? |
05-17-2016, 13:54 | #4 (permalink) |
Member: 431775 Status: Offline Thanks Meter: 94 | mobile stop on flash and don't work after back it to last update from kiss stop on Samsung logo and when try to rest factory now i don't red E:failed to mount /efs (Invalid argumen) efs damages so at last i went it work as before |
The Following User Says Thank You to bahaqurini For This Useful Post: |
05-17-2016, 14:42 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to reflash the phone with "J700HXXU2APC5_J700HODD2APC1_NPL_Android_5.1.1 " firmware from the Support Area and check whether "E:failed to mount /efs (Invalid argumen)" error remains in Recovery Mode. |
