02-11-2015, 20:08 | #1 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Can't use other box's UART with Octopus Before you start saying "troubleshoot the basics" here is what I've done: Phone is set in DM+MODEM+ADB mode in *#0808# Phone is set to PDA/AP in *#7284# VF Battery terminal is covered There is a C3300k cable being used I'm able to send AT and AT+MSLSECUR=1,0 commands over DFS, so I know the UART port works (drivers are loaded successfully) and the cable is right, but Octopus just fails to write the CERT or even recognize the UART interface. The lights on the box for Rx and Tx aren't even blinking. I think only the Rx blinks, the Tx doesn't blink at all (or vice versa...) I tried with the another software, and it repairs the IMEI fine without changing anything. So I know the box, cable, and drivers aren't to blame. Is there anything that I can do to resolve this issue or should I just throw the box into the nearest river? |
The Following User Says Thank You to ecs87 For This Useful Post: |
02-11-2015, 21:06 | #5 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I've tried selecting all the N910 series models. None of them work. It's like as if the software isn't even able to send the AT or AT+FACTORST command to the phone...YET I can send AT commands fine using a terminal: |
02-11-2015, 21:30 | #6 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | This makes no sense...if I'm able to talk to it via a terminal the octopus software should definitely work. I'm so mad...(not at the supporters or software but) with these Damn ftdi uart drivers. I'm 99% sure this is the cause of it. The drivers are fine obviously since they work via terminal but they might be conflicting with the octopus software. |
02-11-2015, 21:46 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | This problem indeed may be caused by drivers conflict. Try to completely uninstall FTDI drivers, then install FTDI drivers 2.08.24. Try to perform operation on another, clean (with only necessary drivers and Software) PC. Also, upload *.log and *.logx files of "Write Cert" operation, we will also check where can be the problem. |
02-11-2015, 21:47 | #8 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Already sent you the log via PM. But here it is: Here's the log: Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\11-02-2015_14-50-28.log" created (2/11/2015 2:50:36 PM). ERROR : 2/11/2015 2:50:38 PM > Access violation at address 00944B2C in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 2/11/2015 2:50:41 PM > Set up system language English (file: English.ini) INFO : 2/11/2015 2:50:41 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.8.3 INFO : 2/11/2015 2:50:41 PM > ----------------------------------------------------------------------------------- INFO : 2/11/2015 2:50:41 PM > To connect SM-N910A phone you have to perform the following steps: INFO : 2/11/2015 2:50:41 PM > 1. Disconnect USB cable from phone. INFO : 2/11/2015 2:50:41 PM > 2. Go to Menu->Settings->More->About Device. INFO : 2/11/2015 2:50:41 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2/11/2015 2:50:41 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 2/11/2015 2:50:41 PM > 5. Turn on "USB Debugging" option. INFO : 2/11/2015 2:50:41 PM > 6. Go to dial window. INFO : 2/11/2015 2:50:41 PM > 7. Enter "*#0808#" number. INFO : 2/11/2015 2:50:41 PM > 8. Select "DM+Modem+ADB". INFO : 2/11/2015 2:50:41 PM > 9. Press Home button. INFO : 2/11/2015 2:50:41 PM > 10. Go to dial window. INFO : 2/11/2015 2:50:41 PM > 11. Enter "*#9090#" number. INFO : 2/11/2015 2:50:41 PM > 12. Set "Diag config" to "USB" value. INFO : 2/11/2015 2:50:41 PM > 13. Restart phone. INFO : 2/11/2015 2:50:41 PM > 14. Press "Read Info" in software. INFO : 2/11/2015 2:51:03 PM > ----------------------------------------------------------------------------------- INFO : 2/11/2015 2:51:03 PM > Platform: Samsung Android INFO : 2/11/2015 2:51:03 PM > Selected port: COM6 INFO : 2/11/2015 2:51:03 PM > Selected model: SM-N910A INFO : 2/11/2015 2:52:49 PM > Selected file: \\7.93.216.107\Shared\GSM\NEWNoteEdgeCERT26.cert WARN : 2/11/2015 2:52:54 PM > Perform the following steps: WARN : 2/11/2015 2:52:54 PM > 1. Connect phone via UART cable to the Box. WARN : 2/11/2015 2:52:54 PM > 2. Note: phone screen must be active INFO : 2/11/2015 2:52:54 PM > Connecting to phone, please wait... ERROR : 2/11/2015 2:54:02 PM > Writing Certificate failed I'll try those drivers in the link you just supplied and report back! |
02-11-2015, 21:49 | #9 (permalink) |
Banned Join Date: Jan 2015 Location: Inside Samsung Age: 39
Member: 2326685 Status: Offline Sonork: [email protected] Thanks Meter: 17 | Ecs87, I don't think a lot of people would be able to help you out here.... try asking from dest or hellothere777... this is beyond my small brain.... I think it could be the drivers... recently I have been struggling with them... still with usb redirector... I have issues... |
02-11-2015, 22:02 | #10 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I didn't think I'd be able to get much help but I figured it'd be worth a shot lol. It's not a HUGE issue, since the software works with all other FTDI UART interfaces, but I was just wondering why NSPRO was the only interface it doesn't work with...? |
02-12-2015, 21:15 | #13 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | I Haven't been here for couple of days and maybe ill be gone for good ... But anyways ... Very easy ... Connect your (z3x or SPT Box) at the same time and use that UART Interface instead Octopus ... |
