08-16-2015, 15:16 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2211339 Status: Offline Thanks Meter: 0 | Cert Samsung s5 sm-900f [Solved] thanks i must repair imei need last step to write cert. thanks Last edited by Octopus box; 08-26-2015 at 09:20. |
08-16-2015, 15:37 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2011 Location: APPEL
Member: 1707492 Status: Offline Thanks Meter: 606 | her is working cert file .. but i need e500h you won to help me plesse give me |
The Following User Says Thank You to MATELECOM1 For This Useful Post: |
08-16-2015, 17:47 | #3 (permalink) |
Member: 2211339 Status: Offline Thanks Meter: 0 | give me this error WHEN use step repair security wipe security: so i can't write certificated help' ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G900F Detected phone model: SM-G900F Firmware compiled date: Thu Apr 9 17:43:03 KST 2015 PDA version: G900FXXU1BOD3 CSC version: G900FWIN1BOD1 SW version: G900FXXU1BOD3 Phone IMEI: Unknown Phone SN: R58F90092SL Android version: 5.0 (LRX21T) Reading info... Phone was not found on the selected port! |
08-17-2015, 04:38 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Do this: Turn on "USB Debugging" option. Go to dial window. Enter "*#0808#" number. Select "DM+Modem+ADB". Press Home button. Restart phone. then choose Com port then Unlock. Br, xerraco |
08-20-2015, 17:42 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please post here full Software log of "Write Cert" operation. What IMEI has the phone after "Wipe Security" operation? |
08-21-2015, 11:54 | #7 (permalink) |
Member: 2211339 Status: Offline Thanks Meter: 0 | Welcome to Octoplus/Octopus Box Samsung software version 2.0.0 ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G900F Mode: Normal Phone model: SM-G900F Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 3 2014 Firmware released time: 11:32:19 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G900F Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FWIN1ANG2 SW version: G900FXXU1ANG2 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 3 2014 Firmware released time: 11:32:19 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900F-21-08-2015_12-47-18-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 3 2014 Firmware released time: 11:32:19 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G900F Selected file: C:\Users\UTENTE\Desktop\SM-G900F_35255806745641_ 0478.cert\SM-G900F_35255806745641_0478.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Checking Certificate file... THIS IS THE PROBLEM |
08-21-2015, 12:31 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Cert file, which You are trying to write is not passing the check. Try to write Cert file from the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. |
08-22-2015, 14:48 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Try to write Cert file from the Support Area, then check phone's IMEI. Post here results and Software log of the operation. |
