01-13-2019, 10:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | SM-N920C frp remove done ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Reset FRP - UART UFS Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Checking operation...OK Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.7.5 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-N920C into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Reading PIT... PIT was read successfully. Performed by 2.7.5 Software version. |
The Following User Says Thank You to lerner_ For This Useful Post: |
