04-05-2014, 17:32 | #1 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Difficult to repair samsung Gt-i9250 [Solved] |
04-05-2014, 17:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please always read Software manual ("Help" button in Software) before to perform any action. To Repair IMEI, do the next: 1. Install the latest software version (http://octoplusbox.com/en/download/software/]). 2. Write into the phone the special firmware "GT-I9250_for_IMEI_repair" from the Support Area. 3. Put phone in Download Mode by pressing "Volume-" + "Power ON" keys. 4. Connect the phone to PC via Micro USB cable. 5. Install required driver. 6. Enter correct IMEI. 7. Click "IMEI fix" button. 8. Follow software instructions (prompts). When Software ask, You should connect the phone by using Samsung Micro UART cable. Last edited by Octopus box; 04-05-2014 at 19:05. |
04-07-2014, 14:44 | #3 (permalink) | |
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Quote:
Team OCTOPLUS've done all these steps, I used an earlier version because with it succeeds with another device, I now have more difficulties with this look at the error in the new version does not find the device | |
04-07-2014, 14:56 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Have You re-flashed the phone with special firmware? Post here full Software log with write firmware operation. Have You connected the phone with Samsung Micro UART C3300k/C3303k with 525kOhm resistor inside? |
04-07-2014, 15:18 | #5 (permalink) | |
Code: Bemvindo na Octoplus/Octopus Box Samsung software versão 1.5.2 Seleccione o arquivo de firmware: GT-I9250_for_IMEI_repair.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9250 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Power" buttons. Found phone on Firmware write started. Escrevendo a secção PIT... A secção PIT foi escrita com êxito Escrevendo a secção xloader... A secção xloader foi escrita com êxito Escrevendo a secção boot... A secção boot foi escrita com êxito Escrevendo a secção recovery... A secção recovery foi escrita com êxito Escrevendo a secção system... A secção system foi escrita com êxito Escrevendo a secção userdata... A secção userdata foi escrita com êxito Escrevendo a secção radio... A secção radio foi escrita com êxito Escrevendo a secção cache... A secção cache foi escrita com êxito A escritura do firmware foi completada com êxito Code: Bemvindo na Octoplus/Octopus Box Samsung software versão 1.5.2 Seleccione o arquivo de firmware: GT-I9250_for_IMEI_repair.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9250 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Power" buttons. Found phone on Firmware write started. Escrevendo a secção PIT... A secção PIT foi escrita com êxito Escrevendo a secção xloader... A secção xloader foi escrita com êxito Escrevendo a secção boot... A secção boot foi escrita com êxito Escrevendo a secção recovery... A secção recovery foi escrita com êxito Escrevendo a secção system... A secção system foi escrita com êxito Escrevendo a secção userdata... A secção userdata foi escrita com êxito Escrevendo a secção radio... A secção radio foi escrita com êxito Escrevendo a secção cache... A secção cache foi escrita com êxito A escritura do firmware foi completada com êxito ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM1 Modelo seleccionado: GT-I9250 IMEI antigo: Unknown Novo IMEI: 353524-01-157411-0 Put phone in Download mode: "Volume down" + "Power button" keys, and connect USB cable. Phone found. Escrevendo a secção EFS... A secção EFS foi escrita com êxito Please disconnect USB cable. After phone reboot and power on, please conect it to box via COM cable. Searching for a phone. Please wait... | |
04-07-2014, 15:23 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to use other Samsung Micro UART C3300k/C3303k with 525kOhm resistor inside. Most likely, the problem is with your cable. Also, look here: http://forum.gsmhosting.com/vbb/9814369-post1185.html, http://forum.gsmhosting.com/vbb/f684...8/#post9211609, http://forum.gsmhosting.com/vbb/f684...0/#post9320418, http://forum.gsmhosting.com/vbb/f684...7/#post9426626. |
04-07-2014, 15:31 | #8 (permalink) | |
04-07-2014, 20:18 | #9 (permalink) |
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Sucessfull Thanks ... Code: Bemvindo na Octoplus/Octopus Box Samsung software versão 1.5.2 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM1 Modelo seleccionado: GT-I9250 IMEI antigo: Unknown Novo IMEI: 353242-49-683007-7 Put phone in Download mode: "Volume down" + "Power button" keys, and connect USB cable. Phone found. Escrevendo a secção EFS... A secção EFS foi escrita com êxito Please disconnect USB cable. After phone reboot and power on, please conect it to box via COM cable. Searching for a phone. Please wait... Phone found. Writing new IMEI. Please wait... Wrong AK number Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM5 Modelo seleccionado: GT-I9250 IMEI antigo: Unknown Novo IMEI: 353242-49-683007-7 Put phone in Download mode: "Volume down" + "Power button" keys, and connect USB cable. Phone found. Escrevendo a secção EFS... A secção EFS foi escrita com êxito Please disconnect USB cable. After phone reboot and power on, please conect it to box via COM cable. Searching for a phone. Please wait... Phone found. Writing new IMEI. Please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
