08-19-2016, 18:43 | #1 (permalink) |
No Life Poster Join Date: Jun 2003
Member: 30754 Status: Offline Thanks Meter: 9 | downloding firmware failed on g925t Welcome to Octoplus/Octopus Box Samsung software version 2.3.2 ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G925TUVS3DOJC_G925TTMB3DOJC_TMB_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.2 software version |
08-20-2016, 04:34 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to write "g925tuvu4epf1_g925ttmb4epf1_tmb_android_6.0.1 " firmware from the Support Area and post here the result. |
