12-03-2013, 03:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | E1280 after flash blinking Code: Welcome to Octoplus/Octopus Box Samsung software version 1.4.1 Selected firmware file: E1280XXLL2_OXALL2.oct ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM11 Selected model: GT-E1280 Selected port: USB To connect GT-E1280 phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold central button connect USB cable. 3. Connect battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing PS section... PS section has been written successfully. Writing CSC section... CSC section has been written successfully. Please, restart the phone to apply changes Firmware writing successfully completed. Thanks in advance |
12-03-2013, 16:19 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to make Format ("Format" button in Software) and then write firmware again. Also try to make Repair NV. |
12-05-2013, 19:48 | #4 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Code: Welcome to Octoplus/Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM42 Selected model: GT-E1280 Selected port: USB To connect GT-E1280 phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold central button connect USB cable. 3. Connect battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Repairing NV section... NV section successfully repaired. Welcome to Octoplus/Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM42 Selected model: GT-E1280 Selected port: USB To connect GT-E1280 phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold central button connect USB cable. 3. Connect battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Writing new IMEI. Please wait... New IMEI successfully written. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM42 Selected model: GT-E1280 Selected port: USB To connect GT-E1280 phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold central button connect USB cable. 3. Connect battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully nv ok imei ok but same problem phone after show samsung logo blinking |
12-06-2013, 09:31 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We will research the problem and say You the result. Now, try to re-flash the phone by using original Samsung falsher and firmware and write the result. |
12-07-2013, 07:20 | #6 (permalink) |
Freak Poster Join Date: May 2013 Location: mumbai
Member: 1937491 Status: Offline Sonork: 100.1646083 Thanks Meter: 7 | Upload E-1200T flash file Hi octopus Team, Plz upload samsung E-1200T flash file on support area,bcoz the converting file are created for different file format and error is coming in flashing between process and set are blink conditon. Also add hindi marathi language file in firware for customer satisfaction.I have hindi Marathi language flash file bt octopus firmware not write successfully. Thanks in Advance Regards, Nasir Memon [email protected] |
12-07-2013, 09:24 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ nmemon786 Hello. Quote:
12-07-2013, 11:40 | #8 (permalink) |
Member: 1937491 Status: Offline Sonork: 100.1646083 Thanks Meter: 7 | samsung E1200T hindi Language link Below is the Hindi marathi language flash file link E1200TDDLL2_BIN - Download - 4shared - Nasir Memon Plz revert me ASAP. thnks in advance Regard, Nasir Memon |
12-07-2013, 12:05 | #10 (permalink) |
Member: 1937491 Status: Offline Sonork: 100.1646083 Thanks Meter: 7 | first convert this file and tried to octopus box but it showing error "the file is created for different file format" in between the process and flashing stop.set was came in blink condition.I tried with many times but not success, After that i tried same firmware in Z3x box ,the flashinf successfully done without any error. |
12-07-2013, 12:10 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
12-07-2013, 13:09 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Also, if your phone is working now, please read Full flash from it, upload somewhere and post here link; we will upload it into the Support Area. |
12-07-2013, 13:10 | #13 (permalink) |
Member: 1937491 Status: Offline Sonork: 100.1646083 Thanks Meter: 7 | Dear Sir, Right now i dont have any e-1200T set in my hand .I done in z3x box and gave to customer bcoz customer are not waiting for more time.so when the same set will come i will upload the logs.before u told me to upload the file we will check and revert u.so plz u check same firmware and revert me i already check it. also I dont have logs and full flash bcoz set is not in my hand as i told above. Plz octopus team check the same firmware if u have same set for more help to ur customer satisfaction. Last edited by nmemon786; 12-07-2013 at 13:15. |
