08-13-2013, 01:10 | #1 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1790385 Status: Offline Thanks Meter: 2 | my octopusbox show me a bluescreen when plugged in - windows 8 [Solved] When i boot the first time to win8 there is no Problem - Card is installed - Software starts.. seems to be good. After installing my "System" and updates (I donīt know what it could be) - a bluescreen which says: non paged fault aerea - somthing in this way. Have changed usbports and it want to install Driver (i see) but then bluescreen. So what can i do ?? I had Setup my System 2 times and it seems that i made the same mistake. Can somebody help please - I donīt know further or to fix this Problem. My System is win8 64bit/ 16GB/AmdFX Eight-Core 4Ghz. Thanks for any help Last edited by Octopus box; 08-14-2013 at 06:29. |
08-13-2013, 02:13 | #2 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Marawi City - MeranaoNians
Member: 1844043 Status: Offline Sonork: 100.1618092 Thanks Meter: 47 | Sir, i can be advice for you.. can make me help you a little. 1st step. reinstall the properly driver of box bcouse of conflic. 2nd step. restart the pc 3rd step. now you can do again perfectly install not at all only directory of suite driver. hope can be help you this method .. good luck. :-) |
The Following User Says Thank You to nasleeck For This Useful Post: |
08-13-2013, 03:53 | #3 (permalink) |
Member: 1790385 Status: Offline Thanks Meter: 2 | first thx for trying to help, the driver arnīt installed, so i can not delete. the 3rd time i set up my System - it must be an update. Once again this problem .. hmm After updates the System donīt come up when the box is plugged in. And if i plug in later (after reboot) --> bluescreen I think itīs a microsoft update problem - so iīve to search which ones. Maybe an update in future fix it - but i donīt think so.. Never had Problems to the box - itīs a good one. Thanks for help or further Solutions |
08-13-2013, 22:27 | #4 (permalink) |
Member: 1790385 Status: Offline Thanks Meter: 2 | I got a solution :-) and solved troubles It was definitly a Driver Problem - my error was not to connect box before motherboarddriver are installed -> Driver conflikt -> bluescreen -> down Now everthing fits, only one thing: If box is connected there is no boot for windows 8 but there is also a new message in 1.2.8 only to connect box if needed -> in this way i can do without troubles nice day @ll Jürgen |
