10-20-2015, 11:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | enable diag not work how to reslove this Code: INFO : 19.10.2015 19:34:59 > ----------------------------------------------------------------------------------- INFO : 19.10.2015 19:35:00 > Platform: Samsung Android INFO : 19.10.2015 19:35:00 > Selected port: COM14 INFO : 19.10.2015 19:35:00 > Selected model: SM-G900F INFO : 19.10.2015 19:35:01 > ADB server killed. WARN : 19.10.2015 19:35:03 > Please, press "OK" button on the phone to allow USB debugging.. WARN : 19.10.2015 19:35:06 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 19.10.2015 19:35:08 > Detected phone model: SM-G900F INFO : 19.10.2015 19:35:08 > Firmware compiled date: Thu Dec 18 17:40:19 KST 2014 INFO : 19.10.2015 19:35:09 > PDA version: G900FXXU1BNL9 INFO : 19.10.2015 19:35:09 > CSC version: G900FLUX1BNL3 INFO : 19.10.2015 19:35:10 > SW version: G900FXXU1BNL9 INFO : 19.10.2015 19:35:11 > Phone IMEI: Unknown INFO : 19.10.2015 19:35:12 > Phone SN: R58G21SP47X INFO : 19.10.2015 19:35:12 > Android version: 5.0 (LRX21T) INFO : 19.10.2015 19:35:12 > Updating DIAG confing... INFO : 19.10.2015 19:35:13 > DIAG confing is succesfully enabled. INFO : 19.10.2015 19:35:43 > ----------------------------------------------------------------------------------- |
10-20-2015, 12:29 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Quote:
unroot the phone and simply enable cp loging mode, by going into recovery | |
The Following User Says Thank You to nadirghazi For This Useful Post: |
10-20-2015, 12:54 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please enter *#0808# and select DM+Modem+ADB option. Connect the phone directly to PC and try to read phone's info from "Main" tab of the Software. |
10-20-2015, 17:18 | #4 (permalink) | ||
Member: 1918391 Status: Offline Thanks Meter: 73 | Quote:
only needed unlock | ||
10-20-2015, 17:49 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please install the latest Software version and repeat "Enable DIAG" operation. Reconnect the phone directly to PC and check, whether it will be detected correctly. If problem will remain the same - try to reflash the phone with any firmware from the Support Area, then check whether Recovery Mode contains "Enable CP logging" option. |
