08-06-2013, 17:28 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1995457 Status: Offline Thanks Meter: 0 | error reading GT-E2121L optoplusbox Modelo seleccionado: GT-E2121L Puerto seleccionado: COM17 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... Error |
08-08-2013, 01:21 | #3 (permalink) |
Member: 1995457 Status: Offline Thanks Meter: 0 | Here the results: Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... Error. Since I have the octopus box I could not run and tested eh E2121L - E2220 - B3410 - I9300 and none is recognized UART cable... |
08-08-2013, 03:31 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | @tkbxunlock What version of Octoplus/Octopus Samsung are you using? 1. You can also Check Cable if cable is broken. 2. Uninstall software restart PC then delete old Octoplus Samsung folder then Download and install the latest version of the Octoplus/Octopus Samsung |
The Following User Says Thank You to GSM_STREET For This Useful Post: |
08-08-2013, 17:25 | #5 (permalink) |
Member: 1995457 Status: Offline Thanks Meter: 0 | Octoplus/Octopus Samsung : 1.2.8 1. cables look good 2. perform the installation of all the software and drivers on two pc with windows seven 64 and windows xp sp3, operation is the same in both. the cables I've tried are the MICRO UART SAM - SAM E210 + USB - SAM C3303K |
08-08-2013, 18:29 | #6 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR Max | |
The Following User Says Thank You to allumts For This Useful Post: |
08-09-2013, 15:16 | #9 (permalink) |
Member: 1995457 Status: Offline Thanks Meter: 0 | hello, I can not connect any phone via UART, and check its performance on various phones, E2121L - e2220 - b3410 - i9300 and does not work please tell me where to send it to the technical review, the product is under warranty GsmServer. |
08-09-2013, 15:40 | #10 (permalink) | |
Please also put in exclusion all Sw .exe of OCTOPUS/PLUS, the Updater and main setup, same whith u Antivirus, try now and post Full Log , BR Max | |
08-09-2013, 15:47 | #11 (permalink) | |
this NO: Code: Here the results: Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. FOUND, Uart Cable is working Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... Error. Ceck directory and ceck the other thinghs above, u are wrong in configuraction Sw, Pc, or Box, for me..... Last edited by allumts; 08-09-2013 at 15:53. | |
08-09-2013, 16:14 | #12 (permalink) |
Member: 1995457 Status: Offline Thanks Meter: 0 | hi. Bienvenido en Octoplus/Octopus Box Samsung software versión 1.2.8 ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 460800 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... |
08-09-2013, 16:43 | #13 (permalink) |
Member: 1995457 Status: Offline Thanks Meter: 0 | first of all thanks for your help. (Netframework / c + + updated / antivirus off) I gather that is the connector RJ45/SERVICE CABLE, because using the cable for gt-e2220 and i9300 MICROUSB/RJ45 returns this log. Plataforma: Samsung Swift Modelo seleccionado: GT-E2220 Puerto seleccionado: COM12 Baud rate: 115200 Plase, connect phone to UART cable, insert battery and press shortly power button Conectando always remains in connecting ... |
08-09-2013, 17:54 | #14 (permalink) | |
E2220 and I9300 are working first part whith Minimicrousb cable, "READ INFO", whith UART cable 525k resistor inside, for Unlock, Imei Repair, and where sw requiere. OK? __________________________________________________ _______ The E2121L is Swift platform and NOT WORK whith any UART cable. E2121L is working whith E210 Usb and RJ45 connector, togheter in the BOX, other side in the Phone. __________________________________________________ _______ - E2220 and I9300 have need of PREPARE PHONE first of connect to the box and to work, Use HELP button and what u read in Sw for any operaction u have need. __________________________________________________ _________ -E2121L, many times have need to check Eeprom, Flash Full Fw whith all files inside, but for First Connection, these are the steps: COM connection -Connect phone to box with E210+USB cable, w/o Battery -Insert battery -Press and hold power button. I hope now is clear, or write what u want do, i think is more good, anyway these are the steps for these 3 phones model, Br Max P.d. amigo, no vaja a mostrar el Log escribido para la mita, muestra Todo el log completo cada mobiles... Last edited by allumts; 08-09-2013 at 18:01. | |
08-12-2013, 16:30 | #15 (permalink) | |
Member: 1995457 Status: Offline Thanks Meter: 0 | Quote:
Bienvenido en Octoplus/Octopus Box Samsung software versión 1.2.8 ----------------------------------------------------------------------------------- Reading EEPROM... Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Reading EEPROM... Reading EEPROM Failed ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Conectando Connecting canceled. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Conectando Connecting canceled. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Conectando Connecting canceled. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM12 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM12 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Conectando Connecting canceled. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM12 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ----------------------------------------------------------------------------------- Reading Full Flash Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Reading Full Flash Reading Full Flash Failed ----------------------------------------------------------------------------------- Plataforma: Samsung Swift Modelo seleccionado: GT-E2121L Puerto seleccionado: COM13 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... | |
