12-23-2013, 23:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: ....
Member: 750419 Status: Offline Sonork: 100.1604828 Thanks Meter: 45 | error repair imei i8260 [Solved] ----------------------------------------------------------------------------------- To connect GT-I8260 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM611 Modelo seleccionado: GT-I8260 Modo: Normal Modelo del teléfono: GT-I8260 Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 Versión del SW: 8X25-SSOSKOLYM-2035 IMEI antiguo: 358922-05-054675-6 IMEI nuevo: xxxxxxxxxxx Searching for a phone. Please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Cheking Root Phone is Rooted Repairing network... Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM611 Modelo seleccionado: GT-I8260 Modo: Normal Modelo del teléfono: GT-I8260 Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 Versión del SW: 8X25-SSOSKOLYM-2035 IMEI antiguo: 358922-05-054675-6 IMEI nuevo: xxxxxxxxxxx Searching for a phone. Please wait... Fecha de creación del firmware: Tue Jul 30 16:10:12 KST 2013 PDA Version: I8260LUBAMG3 CSC Version: I8260LUWAAMG2 Versión del SW: I8260LUBAMG2 IMEI del teléfono: 358922050546756 Phone SN: RV1D93TM5MJ Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed Last edited by Octopus box; 01-01-2014 at 10:40. |
12-23-2013, 23:50 | #2 (permalink) |
Registered User Join Date: Sep 2009 Location: 01100001 01110001 01110101 011
Member: 1128665 Status: Offline Sonork: 100.1605565 Thanks Meter: 11 | me to Plataforma: Samsung Anycall Puerto seleccionado: COM33 Modelo seleccionado: GT-I8260L Modo: Normal Modelo del teléfono: GT-I8260L Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 Versión del SW: 8X25-SSOSKOLYM-2035 IMEI antiguo: 357735-05-065833-5 IMEI nuevo: 357735-05-865833-7 Searching for a phone. Please wait... ADB server killed. Fecha de creación del firmware: Thu Jul 18 15:28:14 KST 2013 PDA Version: I8260LUBAMG2 CSC Version: I8260LTFGAMG2 Versión del SW: I8260LUBAMG2 IMEI del teléfono: 357735050658335 Phone SN: RV1D927F6HB Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed |
12-23-2013, 23:51 | #3 (permalink) |
Member: 1128665 Status: Offline Sonork: 100.1605565 Thanks Meter: 11 | Octoplus/Octopus Box Samsung Software v1.4.3 Release Notes Added support for the following models: - GT-I8260L - added Direct Unlock, Repair IMEI (world's first), Read Codes, Write Firmware, Read/Write/Repair NVM. ???????????????? ??????????????? |
12-23-2013, 23:58 | #4 (permalink) |
Member: 1128665 Status: Offline Sonork: 100.1605565 Thanks Meter: 11 | the unlock is done, but write imei failed Plataforma: Samsung Anycall Puerto seleccionado: COM33 Modelo seleccionado: GT-I8260L Modo: Normal Modelo del teléfono: GT-I8260L Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 IMEI del teléfono: 357735-05-065833-5 Versión del SW: 8X25-SSOSKOLYM-2035 Liberando el teléfono... El teléfono ha sido liberado con éxito |
12-24-2013, 07:39 | #5 (permalink) | |
Insane Poster Join Date: Dec 2008 Location: Argentina
Member: 916783 Status: Offline Thanks Meter: 14 | Quote:
This is the correct process: 1.- Flash (GT-I8260L_for_IMEI_Repair.oct) (bricked). 2.- flash with odin 1.85 (this version, dont 3.xx), firmware stock (I8260XXAMG3_I8260LUXAMG1_I8260XXAMG4_HOME.tar.md5 ) samfirmware. Give it an error but the phone power on. 3.- Root with Framaroot-1.8.0.apk (second exploit) 4.- Repair imei with Octopus. | |
12-24-2013, 07:52 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ distriaccel Hello. To perform Repair IMIE operation You need to root the phone and use SuperSU, press "Allow" button on the phone every time when superuser dialog appears. Or You need to write of the special rooted firmware "GT-I8260L_for_IMEI_Repair.oct" from the Support Area and then perform Repair IMEI operation. |
12-27-2013, 00:57 | #8 (permalink) | |
Member: 750419 Status: Offline Sonork: 100.1604828 Thanks Meter: 45 | Quote:
12-27-2013, 09:26 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ javsoft To make Repair IMEI please do the next: 1. Write firrmware "I8260XXAMG3_I8260LUXAMG1_I8260XXAMG4_HOME.oct " from the Support Area. 2. Root the phone. 3. Perform Repair IMEI operation. 4. Post here the result. |
12-28-2013, 09:34 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try also to write firmware another one firmware for GT-I8260L ("I8260XXAMG3_I8260OXXAMG4_I8260XXAMG4_HOME") from the Support Area and repeat all operations I have written above again. Also, maybe, your phone model is GT-I8260 (not GT-I8260L). Try also to write firmwares for GT-I8260 and write here the result. |
12-28-2013, 20:25 | #13 (permalink) | |
Do this: Download this firmware Download I8260XXAMG3 I8260LUXAMG1 LUX zip or Download file I8260XXAMG3_I8260LUXAMG1_LUX.zip (is the same, different host) With Odin 1.85 (dont other version, please download 1.85 version) flash the firmware, it gives an error but the phone power on. Root with framaroot, make unlock/repair with Octopus. | |
12-31-2013, 17:43 | #15 (permalink) |
Member: 1128665 Status: Offline Sonork: 100.1605565 Thanks Meter: 11 | ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM33 Modelo seleccionado: GT-I8260L Modo: Normal Modelo del teléfono: GT-I8260L Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 Versión del SW: 8X25-SSOSKOLYM-2035 IMEI antiguo: 357735-05-065833-5 IMEI nuevo: 365589-25-569669-3 Searching for a phone. Please wait... Fecha de creación del firmware: Wed Jul 17 14:46:59 KST 2013 PDA Version: I8260XXAMG3 PDA Version: Unknown Versión del SW: I8260LUBAMG2 IMEI del teléfono: 357735050658335 Phone SN: RV1D927F6HB Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Fecha de creación del firmware: May 07 2013 Tiempo de compilación del firmware: 14:00:00 Fecha de salida del firmware: Jul 18 2013 Tiempo de salida del firmware: 18:13:15 Versión del SW: 8X25-SSOSKOLYM-2035 Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to distriaccel For This Useful Post: |
