07-24-2017, 11:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2308972 Status: Offline Thanks Meter: 10 | error in repairing imei in samsung on8 ----------------------------------------------------------------------------------- To connect SM-G610Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J710FN Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J710FN Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J710FN Firmware compiled date: Fri Oct 7 14:13:18 KST 2016 PDA version: J710FNDDU1APJ1 CSC version: J710FNODD1API9 SW version: J710FNDDU1API9 Android version: 6.0.1 (MMB29K) Sales code: INS Country: India HW platform: exynos5 HW Chip: exynos7580 HW Modem: SHANNON310 Security patch level: 2016-10-01 SIM 1 status: absent SIM 2 status: absent Codename: j7xltedd Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J710FN-Unknown24-07-2017_16-12-37-.asec file Connecting to modem port... Found phone on COM75 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Write IMEI failed Performed by 2.5.4 Software version. |
07-24-2017, 12:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Phone doesn't respond on Software CMDs sent via Modem port. At first, please re-install Samsung USB drivers, then try to process the phone again. Try to use different USB ports of PC motherboard for connection of the phone. If problem will remain the same - most likely phone has firmware with new type of Security. In such case You can try to write older (by release date) firmware, or only its modem, then repeat "Repair IMEI" operation. |
07-25-2017, 11:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please post here Software log of "Repair IMEI" operation, which You've performed after firmware/modem downgrading. |
