06-10-2014, 18:52 | #1 (permalink) |
Junior Member Join Date: Jun 2014 Location: California
Member: 2202561 Status: Offline Thanks Meter: 3 | error unlocking samsung i527 |
06-10-2014, 19:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. In order to connect the phone, please carefully perform all of the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. (re enable it, if is already enabled) 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart the phone. 14. Connect the phone directly to PC. 15. Press "Read Info" in software. Note, that in order to unlock this phone it needs to be rooted. Root the phone, turn on USB Debugging Mode and repeat the operation. Then post here full Software log with all of your actions. Last edited by Octopus box; 06-11-2014 at 06:59. |
