12-22-2014, 12:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | Factory Unlock Samsung i9301i [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.7.5 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Connecting to server... Username: emen_suanli Authorizing... Checking balance... Your balance: 22 credits. ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM37 Reading info... Phone model: GT-I9301I Phone IMEI: 35583506747590 MSL address: RV1F91PSZJ Requesting MSL code... Connecting to server Username: emen_suanli Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 22 credits. Checking request.. Sending request... Service is currently not available. Is it down? Because previously no problem. br, s1emens Last edited by Octopus box; 12-23-2014 at 17:35. |
