11-07-2014, 21:05 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1288575 Status: Offline Thanks Meter: 36 | factory unlocked samsung g900a server credits Welcome to Octoplus/Octopus Suite version 1.2.9 -------------------------------------------------------------------------------- Phone must be ON, and screen must be active, connect phone to UART cable. Searching for a phone. Please wait... Found phone on COM16 Reading info... Detected model name: SM-G900A IMEI: 30000000000000 MSL address: R38F50MANW -------------------------------------------------------------------------------- Phone must be ON, and screen must be active, connect phone to UART cable. Searching for a phone. Please wait... Found phone on COM16 Reading info... Detected model name: SM-G900A IMEI: 30000000000000 MSL address: R38F50MANW Requesting the MSL code.. Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Default_user Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...Failed! Too low balance to provide the security operation! Your balance: 0 credits. Needed: 9 credits. -------------------------------------------------------------------------------- Connecting to server...OK Username: user Authorizing...OK Checking balance...OK Your balance: 10 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, Medusa -------------------------------------------------------------------------------- Phone must be ON, and screen must be active, connect phone to UART cable. Searching for a phone. Please wait... Found phone on COM16 Reading info... Detected model name: SM-G900A IMEI: 300000000000 MSL address: R38F50MANW Requesting the MSL code.. Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: user Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Your balance: 10 credits. Checking request.. Sending request.. Order ID: 55297 MSL code obtained successfully! Deactivating MSL... MSL deactivate successfully Unlocking... Factory Unlock operation successfully completed! To unlock please type "00000000" (8 zeros). Please, restart phone to apply changes |
The Following User Says Thank You to clippy165 For This Useful Post: |
12-05-2014, 21:02 | #2 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2002817 Status: Offline Thanks Meter: 0 | Hello, im trying to factory unlock a G900A that i have with my octoplus box. I hook up the correct uart cable but the software does not recognize it. Could you help me to set this us? I try going to *#9090# to change UART mode but it says diag config not support. |
12-05-2014, 21:19 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please block highlighted pin with a tape and try to connect the phone via Samsung Micro UART C3300k/C3303k cable with 523-525kOhm resistor. Last edited by Octopus box; 12-15-2014 at 18:34. |
12-06-2014, 09:49 | #4 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2259435 Status: Offline Thanks Meter: 0 | Samsung SM-G900A Diag Mode Not Supported The exact ServiceMode screen using the *#9090# code is as follows: DIAG CONFIG Not Support I have tried safe mode and everything I can think of with no success. From what I found the SM-G900A has 0 updated roms. Its running Android 4.4.2 I have done the following: Network sim unlocked Rooted USB Debuging on. What is the workaround or solution? Please help |
12-07-2014, 04:25 | #6 (permalink) |
Member: 2259435 Status: Offline Thanks Meter: 0 | Write EFS file Primarily to write EFS files. Occasional IMEI repair. Without diag mode can't repair security, write EFS files. I have seen this issue now with 2 Samsung phones (DIAG CONFIG not support) SM-G386T Galaxy Advent SM-G900A Galaxy S5 Any ideas? |
12-07-2014, 10:08 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Yes, some firmwares don't support diag menu via "*#9090". To connect SM-G900A, do the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Restart phone. 12. Press "Read Info" in software |
12-10-2014, 17:39 | #8 (permalink) |
Member: 2002817 Status: Offline Thanks Meter: 0 | I tried your suggestion. The phone still wont be recognized. I do not think its the cable or the box because i just used this same setup to repair IMEI and unlock a galaxy S 4. |
12-12-2014, 08:37 | #10 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2244302 Status: Offline Thanks Meter: 0 | Hi, I've been using octopus box since May of this Year and I love every minute of it. Today I try to perform factory unlock for my Samsung galaxy s5 sm-g900a but it asking for user name and password. how do I go about to obtain user name and password or to add credit to the account. Please be advise. Thanks |
12-12-2014, 09:05 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, contact to our managers in on-line Sales Chat at www.gsmserver.com, they will help You with credits and account. |
