06-09-2014, 15:16 | #1 (permalink) |
Major Poster Join Date: Jan 2013
Member: 1876441 Status: Offline Thanks Meter: 2 | Flash problem samsung I9295 [Solved] i tried flash with I9295XXUAMF5_OXXAMF4_EUR_Greece_Android_4.2.2.oct log: INFO : 09.06.2014 14:30:31 > Set up system language English (file: English.ini) INFO : 09.06.2014 14:30:31 > Welcome to Octoplus/Octopus Box Samsung software version 1.5.2 INFO : 09.06.2014 14:32:55 > ----------------------------------------------------------------------------------- INFO : 09.06.2014 14:32:55 > To connect GT-I9295 phone you have to perform the following steps: INFO : 09.06.2014 14:32:55 > 1. Disconnect USB cable from phone. INFO : 09.06.2014 14:32:55 > 2. Go to Menu->Settings->More->About Device. INFO : 09.06.2014 14:32:55 > 3.Tap on "Builds numbers" 7 times to enable developer options. INFO : 09.06.2014 14:32:55 > 4. Go to Menu->Settings->More->Developer options. INFO : 09.06.2014 14:32:55 > 5. Turn on "USB Debugging" option. INFO : 09.06.2014 14:32:55 > 6. Go to dial window. INFO : 09.06.2014 14:32:55 > 7. Enter "*#0808#" number. INFO : 09.06.2014 14:32:55 > 8. Select "DM+Modem+ADB". INFO : 09.06.2014 14:32:55 > 9. Close window. INFO : 09.06.2014 14:32:55 > 10. Go to dial window. INFO : 09.06.2014 14:32:55 > 11. Enter "*#9090#" number. INFO : 09.06.2014 14:32:55 > 12. Set "Diag config" to "USB" value. INFO : 09.06.2014 14:32:55 > 13. Restart phone. INFO : 09.06.2014 14:32:55 > 14. Press "Read Info" in software. INFO : 09.06.2014 14:37:51 > ----------------------------------------------------------------------------------- INFO : 09.06.2014 14:37:51 > Platform: Samsung Android INFO : 09.06.2014 14:37:51 > Selected port: COM1 INFO : 09.06.2014 14:37:51 > Selected model: GT-I9295 INFO : 09.06.2014 14:37:53 > Phone was not found on the selected port! INFO : 09.06.2014 14:37:53 > Searching for USB diagnostic port... WARN : 09.06.2014 14:37:53 > No diagnostic ports found! INFO : 09.06.2014 14:37:53 > Connecting to phone on COM4 WARN : 09.06.2014 14:37:53 > Phone connection failed INFO : 09.06.2014 14:39:28 > Selected firmware file: I9295XXUAMF5_OXXAMF4_EUR_Greece_Android_4.2.2.oct WARN : 09.06.2014 14:39:38 > Please switch your phone to the download mode and connect it to a PC. WARN : 09.06.2014 14:39:38 > To put GT-I9295 phone into download mode you have to perform the following steps: WARN : 09.06.2014 14:39:38 > 1. Reconnect phone battery. WARN : 09.06.2014 14:39:38 > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 09.06.2014 14:39:38 > 3. When phone turns on press "Volume+" button. INFO : 09.06.2014 14:39:38 > Found phone on INFO : 09.06.2014 14:39:38 > Firmware write started. INFO : 09.06.2014 14:39:38 > Writing SBL2 section... INFO : 09.06.2014 14:39:40 > SBL2 section has been written successfully. INFO : 09.06.2014 14:39:40 > Writing SBL3 section... INFO : 09.06.2014 14:39:43 > SBL3 section has been written successfully. INFO : 09.06.2014 14:39:43 > Writing RPM section... INFO : 09.06.2014 14:39:45 > RPM section has been written successfully. INFO : 09.06.2014 14:39:45 > Writing ABOOT section... INFO : 09.06.2014 14:40:33 > ABOOT section has been written successfully. INFO : 09.06.2014 14:40:33 > Writing TZ section... INFO : 09.06.2014 14:40:35 > TZ section has been written successfully. INFO : 09.06.2014 14:40:35 > Writing BOOT section... INFO : 09.06.2014 14:40:39 > BOOT section has been written successfully. INFO : 09.06.2014 14:40:39 > Writing CACHE section... INFO : 09.06.2014 14:41:06 > CACHE section has been written successfully. INFO : 09.06.2014 14:41:06 > Writing HIDDEN section... INFO : 09.06.2014 14:41:10 > HIDDEN section has been written successfully. INFO : 09.06.2014 14:41:10 > Writing MDM section... INFO : 09.06.2014 14:41:23 > MDM section has been written successfully. INFO : 09.06.2014 14:41:23 > Writing APNHLOS section... INFO : 09.06.2014 14:41:27 > APNHLOS section has been written successfully. INFO : 09.06.2014 14:41:27 > Writing RECOVERY section... INFO : 09.06.2014 14:41:31 > RECOVERY section has been written successfully. INFO : 09.06.2014 14:41:31 > Writing SYSTEM section... INFO : 09.06.2014 14:48:06 > SYSTEM section has been written successfully. INFO : 09.06.2014 14:48:06 > Firmware writing successfully completed. Last edited by Octopus box; 01-09-2015 at 07:55. |
06-09-2014, 15:23 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Here is secured boot in your device or You have not disabled KNOX before writing firmware. Now You should write the same firmware version, that was in your device before. |
06-09-2014, 15:38 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Currently we have only this one firmware in the Support Area. We will try to find other firmwares and upload them into the Support Area. Also, If You have other original firmwares for this device, You can convert them by using built-in firmware converter ("Firmware converter" button in Software) and then write. |
01-08-2015, 23:11 | #6 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | Quote:
