06-14-2018, 09:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Bulgaria Smolyan
Member: 203747 Status: Offline Thanks Meter: 94 | Flashing problem [Answered] : 13.6.2018 г/ 14:45:37 > 5. Turn on "USB Debugging" option. INFO : 13.6.2018 г/ 14:46:02 > Selected firmware file: J320FNXXU0AQA4_J320FNVFG0AQA2_CYV_Android_5.1.1.oc t WARN : 13.6.2018 г/ 14:46:05 > Please put the phone into Download Mode and connect USB cable. WARN : 13.6.2018 г/ 14:46:05 > To put SM-J320FN into Download Mode, You have to perform the following steps: WARN : 13.6.2018 г/ 14:46:05 > 1. Reconnect the battery. WARN : 13.6.2018 г/ 14:46:05 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 13.6.2018 г/ 14:46:05 > 3. When phone turns on, press "Volume+" key. INFO : 13.6.2018 г/ 14:46:12 > Found phone on WARN : 13.6.2018 г/ 14:46:12 > Advanced mode! INFO : 13.6.2018 г/ 14:46:16 > Firmware write started. INFO : 13.6.2018 г/ 14:46:17 > Writing BOOT section... INFO : 13.6.2018 г/ 14:46:17 > BOOT section has been written successfully. INFO : 13.6.2018 г/ 14:46:17 > Writing SBOOT section... INFO : 13.6.2018 г/ 14:46:17 > SBOOT section has been written successfully. INFO : 13.6.2018 г/ 14:46:17 > Writing SBOOT2 section... INFO : 13.6.2018 г/ 14:46:17 > SBOOT2 section has been written successfully. INFO : 13.6.2018 г/ 14:46:17 > Writing KERNEL section... INFO : 13.6.2018 г/ 14:46:18 > KERNEL section has been written successfully. INFO : 13.6.2018 г/ 14:46:18 > Writing RECOVERY section... INFO : 13.6.2018 г/ 14:46:19 > RECOVERY section has been written successfully. INFO : 13.6.2018 г/ 14:46:19 > Writing SYSTEM section... INFO : 13.6.2018 г/ 14:48:37 > SYSTEM section has been written successfully. INFO : 13.6.2018 г/ 14:48:37 > Writing l_modem section... INFO : 13.6.2018 г/ 14:48:38 > l_modem section has been written successfully. INFO : 13.6.2018 г/ 14:48:38 > Writing l_gdsp section... INFO : 13.6.2018 г/ 14:48:38 > l_gdsp section has been written successfully. INFO : 13.6.2018 г/ 14:48:38 > Writing l_ldsp section... INFO : 13.6.2018 г/ 14:48:38 > l_ldsp section has been written successfully. INFO : 13.6.2018 г/ 14:48:38 > Writing l_warm section... INFO : 13.6.2018 г/ 14:48:39 > l_warm section has been written successfully. INFO : 13.6.2018 г/ 14:48:39 > Writing pm_sys section... INFO : 13.6.2018 г/ 14:48:39 > pm_sys section has been written successfully. INFO : 13.6.2018 г/ 14:48:39 > Writing l_fixnv2 section... INFO : 13.6.2018 г/ 14:48:39 > l_fixnv2 section has been written successfully. INFO : 13.6.2018 г/ 14:48:39 > Writing CACHE section... INFO : 13.6.2018 г/ 14:48:42 > CACHE section has been written successfully. INFO : 13.6.2018 г/ 14:48:42 > Writing HIDDEN section... INFO : 13.6.2018 г/ 14:51:04 > HIDDEN section has been written successfully. ERROR : 13.6.2018 г/ 14:51:04 > Writing Firmware Failed INFO : 13.6.2018 г/ 14:51:04 > Performed by 2.6.9 Software version. WARN : 13.6.2018 г/ this was yesterday and this one is today og file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\14-06-2018_11-08-31.log" created (14.6.2018 г/ 11:08:34). INFO : 14.6.2018 г/ 11:08:42 > Set up system language English (file: English.ini) INFO : 14.6.2018 г/ 11:08:42 > Welcome to Octoplus Box Samsung software version 2.6.9 INFO : 14.6.2018 г/ 11:08:47 > ----------------------------------------------------------------------------------- INFO : 14.6.2018 г/ 11:08:47 > To connect SM-N910C phone you have to perform the following steps: INFO : 14.6.2018 г/ 11:08:47 > 1. Disconnect USB cable from phone. INFO : 14.6.2018 г/ 11:08:47 > 2. Go to Menu->Settings->More->About Device. INFO : 14.6.2018 г/ 11:08:47 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 14.6.2018 г/ 11:08:47 > 4. Go to Menu->Settings->More->Developer options. INFO : 14.6.2018 г/ 11:08:47 > 5. Turn on "USB Debugging" option. INFO : 14.6.2018 г/ 11:09:02 > Selected firmware file: N910CXXS2DPL2_N910COJV2DPJ1_KSA_Android_6.0.1.oct WARN : 14.6.2018 г/ 11:09:08 > Please put the phone into Download Mode and connect USB cable. WARN : 14.6.2018 г/ 11:09:08 > To put SM-N910C into Download Mode, You have to perform the following steps: WARN : 14.6.2018 г/ 11:09:08 > 1. Reconnect the battery. WARN : 14.6.2018 г/ 11:09:08 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 14.6.2018 г/ 11:09:08 > 3. When phone turns on, press "Volume+" key. INFO : 14.6.2018 г/ 11:09:13 > Found phone on WARN : 14.6.2018 г/ 11:09:14 > Advanced mode! INFO : 14.6.2018 г/ 11:09:17 > Firmware write started. INFO : 14.6.2018 г/ 11:09:17 > Writing BOOTLOADER section... INFO : 14.6.2018 г/ 11:09:17 > BOOTLOADER section has been written successfully. INFO : 14.6.2018 г/ 11:09:17 > Writing BOOT section... INFO : 14.6.2018 г/ 11:09:18 > BOOT section has been written successfully. INFO : 14.6.2018 г/ 11:09:18 > Writing RECOVERY section... INFO : 14.6.2018 г/ 11:09:19 > RECOVERY section has been written successfully. INFO : 14.6.2018 г/ 11:09:19 > Writing SYSTEM section... INFO : 14.6.2018 г/ 11:13:29 > SYSTEM section has been written successfully. INFO : 14.6.2018 г/ 11:13:29 > Writing RADIO section... INFO : 14.6.2018 г/ 11:13:33 > RADIO section has been written successfully. INFO : 14.6.2018 г/ 11:13:33 > Writing CACHE section... INFO : 14.6.2018 г/ 11:13:41 > CACHE section has been written successfully. INFO : 14.6.2018 г/ 11:13:41 > Writing HIDDEN section... ERROR : 14.6.2018 г/ 11:14:38 > Writing Firmware Failed INFO : 14.6.2018 г/ 11:14:38 > Performed by 2.6.9 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\14-06-2018_11-08-31.log" closed (14.6.2018 г/ 11:15:40). need help pls P.S. 1 the PC is clean 2 the SW is the latest Last edited by Octopus box; 06-14-2018 at 09:38. |
06-14-2018, 09:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is the problem/state of your devices exactly? Why You have devices to write firmwares? Have You tried to write another firmwares to this devices? Does the devices power on after writing firmwares? |
