10-11-2017, 16:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2279482 Status: Offline Thanks Meter: 1 | FPR j510fFN I downloaded the files combination_fa60_j510fn_j510fnxxu1apd1_cl7558903_q b9320748_rev00 NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Reset FRP/ Reactivation lock operation for SM-J510FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.6.0 Software version. |
10-12-2017, 09:43 | #5 (permalink) |
Member: 2279482 Status: Offline Thanks Meter: 1 | Welcome to Octoplus/Octopus Box Samsung software version 2.6.0 ----------------------------------------------------------------------------------- To connect SM-J510FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-J510FN Searching for a phone (waiting for ADB device)... Operation was canceled Selected firmware file: combination_fa60_j510fn_j510fnxxu1apd1 _cl7558903_qb9320748_rev00.oct Performed by 2.6.0 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-J510FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing QSEE section... QSEE section has been written successfully. Writing QHEE section... QHEE section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing sec section... sec section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing PERSIST section... PERSIST section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Reset FRP/ Reactivation lock operation for SM-J510FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging. Reading info... Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J510FN Firmware compiled date: Thu Apr 21 09:53:32 KST 2016 PDA version: FA60_J510FNXXU1APD1 CSC version: unknown SW version: J510FNXXU1APC8 Phone SN: RF8H82TDXJB Android version: 6.0.1 (MMB29M) Sales code: unknown Country: unknown HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2016-03-01 SIM 1 status: absent Codename: j5xnltexx Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Reset FRP/ Reactivation lock operation for SM-J510FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J510FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.0 Software version. I always reset my menu the cell phone is coming back but always comes back to the maintenance menu |
