04-12-2016, 11:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. You can try to reset FRP lock via "Reset FRP/Reactivation/EE" operation. |
04-12-2016, 12:02 | #3 (permalink) | |
Freak Poster Join Date: May 2013 Location: algeria
Member: 1933548 Status: Offline Thanks Meter: 19 | Quote:
Code: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910H To put SM-N910H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version | |
04-12-2016, 13:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please make Factory Reset and Wipe cache partition from Recovery Mode, then reflash the phone. Repeat "Reset FRP/Reactivation/EE" operation after these actions and post here the result. |
04-12-2016, 20:01 | #5 (permalink) | |
i tried with different firmware 4.4.4 5.0.1 5.1.1 Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-N910H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910H To put SM-N910H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version | |
04-13-2016, 11:10 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
10-27-2016, 17:24 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
Code: INFO : 27.10.2016 19:14:56 > Platform: Samsung Android INFO : 27.10.2016 19:14:56 > Selected port: INFO : 27.10.2016 19:14:56 > Selected model: SM-N910H WARN : 27.10.2016 19:14:56 > To put SM-N910H into Download Mode, You have to perform the following steps: WARN : 27.10.2016 19:14:56 > 1. Reconnect the battery. WARN : 27.10.2016 19:14:56 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 27.10.2016 19:14:56 > 3. When phone turns on, press "Volume+" key. INFO : 27.10.2016 19:14:56 > Searching for a phone. Please wait... INFO : 27.10.2016 19:16:46 > Phone found. INFO : 27.10.2016 19:16:46 > Initializing.. INFO : 27.10.2016 19:16:46 > Resetting FRP lock.. ERROR : 27.10.2016 19:16:46 > not supported INFO : 27.10.2016 19:16:46 > Resetting EE lock.. ERROR : 27.10.2016 19:16:46 > not supported INFO : 27.10.2016 19:16:46 > Resetting Samsung Account lock.. ERROR : 27.10.2016 19:16:46 > not supported ERROR : 27.10.2016 19:16:46 > Operation was failed! INFO : 27.10.2016 19:16:46 > Performed by 2.4.0 Software version. | |
10-28-2016, 07:35 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Reset Reactivation Lock works for Galaxy S6/S6+ and newer phones. |
