09-15-2014, 10:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: madrid spain
Member: 1815849 Status: Offline Thanks Meter: 17 | g3815 4.4.2 imei repair failed 1.6.4 --------------------------------------------------------- -------------------------- To connect SM-G3815 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G3815 Detected phone model: SM-G3815 Firmware compiled date: Wed Jul 30 16:24:56 KST 2014 PDA version: G3815XXUCNH1 CSC version: G3815PHECNH1 SW version: G3815XXUCNH1 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus \Octoplus_Samsung\BACKUP\Security-SM-G3815-15-09-2014_11- 51-53-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Found more then one box connected to COM4 IMEI successfully repaired. Please, restart the phone to apply changes after repair,imei still is 0/1 |
09-15-2014, 11:04 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As I see from your Software log, there can be the problem with phone's EFS: Quote:
Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10479381. | |
09-15-2014, 11:14 | #3 (permalink) | |
Member: 1815849 Status: Offline Thanks Meter: 17 | Quote:
