05-15-2016, 23:34 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2188956 Status: Offline Thanks Meter: 29 | G386T Unlock fail with root [Solved] ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Apr 20 2015 Firmware compiled time: 07:00:00 Firmware released date: Aug 25 2015 Firmware released time: 13:44:00 SW Version: MPSS.DI.2.0.c8-00110-M8926DAAAANAZM-2 Detected phone model: SM-G386T Firmware compiled date: Tue Aug 25 15:10:36 KST 2015 PDA version: G386TUVU1AOH3 CSC version: G386TTMB1AOH3 SW version: G386TUVU1AOH3 Phone IMEI: 352829069353601 Phone SN: R28G12FYJCW Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: afyonltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G386T-15-05-2016_16-31-06 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version says sucessful, but does not work after i put in another sim. says not unlocked. Last edited by Octopus box; 05-16-2016 at 10:51. |
05-15-2016, 23:58 | #2 (permalink) |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Bro, you only need install a stock firmware for Sm-G386T1 to SM-G386T. They are the same phone, this will not brick your phone. I tested really many times. Or now you can install a SM-G386T1 modem from octoplus support and not need to flash all the firmware. When you flashed the phone or instaled the modem, root with CF-Autoroot, SM-G386T works for both of them. And enable diag with the samsung firmware. Then direct unlock and done. |
The Following User Says Thank You to Alexandroid For This Useful Post: |
05-16-2016, 00:11 | #4 (permalink) |
Member: 2395490 Status: Offline Thanks Meter: 515 | I did this one yesterday. You can use The NK3 and NH3 firmware, Both works great INFO : 14/05/2016 6:31:07 > Platform: Samsung Android INFO : 14/05/2016 6:31:07 > Selected port: COM3 INFO : 14/05/2016 6:31:07 > Selected model: SM-G386T1 INFO : 14/05/2016 6:31:07 > Reading info... WARN : 14/05/2016 6:31:07 > Phone was not found on the selected port! ERROR : 14/05/2016 6:31:07 > Phone unlocking failed INFO : 14/05/2016 6:31:07 > Performed by 2.2.6 software version INFO : 14/05/2016 6:31:12 > ----------------------------------------------------------------------------------- INFO : 14/05/2016 6:31:13 > Platform: Samsung Android INFO : 14/05/2016 6:31:13 > Selected port: COM3 INFO : 14/05/2016 6:31:13 > Selected model: SM-G386T1 INFO : 14/05/2016 6:31:16 > Detected phone model: SM-G386T1 INFO : 14/05/2016 6:31:16 > Firmware compiled date: Fri Aug 21 15:52:35 KST 2015 INFO : 14/05/2016 6:31:16 > PDA version: G386T1UVU1AOH2 INFO : 14/05/2016 6:31:16 > CSC version: G386T1TMB1AOH2 INFO : 14/05/2016 6:31:16 > SW version: G386T1UVU1AOH2 INFO : 14/05/2016 6:31:16 > Phone IMEI: 35XXXXXXXXXXXXX INFO : 14/05/2016 6:31:16 > Phone SN: R2XXXXXXXXX INFO : 14/05/2016 6:31:16 > Android version: 4.4.2 (KOT49H) INFO : 14/05/2016 6:31:16 > Country: USA INFO : 14/05/2016 6:31:16 > HW platform: msm8226 INFO : 14/05/2016 6:31:16 > HW Chip: MSM8926 INFO : 14/05/2016 6:31:16 > HW Modem: MSM8926 INFO : 14/05/2016 6:31:16 > Codename: afyonlteMetroPCS INFO : 14/05/2016 6:31:16 > Updating DIAG confing... INFO : 14/05/2016 6:31:17 > DIAG confing is succesfully enabled. INFO : 14/05/2016 6:31:24 > Performed by 2.2.6 software version INFO : 14/05/2016 6:31:37 > ----------------------------------------------------------------------------------- INFO : 14/05/2016 6:31:38 > Platform: Samsung Android INFO : 14/05/2016 6:31:39 > Selected port: COM115 INFO : 14/05/2016 6:31:39 > Selected model: SM-G386T1 INFO : 14/05/2016 6:31:39 > Reading info... INFO : 14/05/2016 6:31:39 > Mode: Normal INFO : 14/05/2016 6:31:39 > Firmware compiled date: Apr 20 2015 INFO : 14/05/2016 6:31:39 > Firmware compiled time: 07:00:00 INFO : 14/05/2016 6:31:39 > Firmware released date: Aug 21 2015 INFO : 14/05/2016 6:31:39 > Firmware released time: 13:41:42 INFO : 14/05/2016 6:31:39 > SW Version: MPSS.DI.2.0.c8-00110-M8926DAAAANAZM-2 INFO : 14/05/2016 6:31:41 > Detected phone model: SM-G386T1 INFO : 14/05/2016 6:31:41 > Firmware compiled date: Fri Aug 21 15:52:35 KST 2015 INFO : 14/05/2016 6:31:41 > PDA version: G386T1UVU1AOH2 INFO : 14/05/2016 6:31:41 > CSC version: G386T1TMB1AOH2 INFO : 14/05/2016 6:31:41 > SW version: G386T1UVU1AOH2 INFO : 14/05/2016 6:31:41 > Phone IMEI: 35XXXXXXXXXXXXX INFO : 14/05/2016 6:31:41 > Phone SN: R2XXXXXXX INFO : 14/05/2016 6:31:41 > Android version: 4.4.2 (KOT49H) INFO : 14/05/2016 6:31:41 > Country: USA INFO : 14/05/2016 6:31:41 > HW platform: msm8226 INFO : 14/05/2016 6:31:41 > HW Chip: MSM8926 INFO : 14/05/2016 6:31:41 > HW Modem: MSM8926 INFO : 14/05/2016 6:31:42 > Codename: afyonlteMetroPCS INFO : 14/05/2016 6:31:42 > Checking Root: INFO : 14/05/2016 6:31:42 > Phone is Rooted. INFO : 14/05/2016 6:31:42 > Reading security backup, please wait... INFO : 14/05/2016 6:32:04 > Backup saved as Security-SM-G386T1-Unknown-14-05-2016_18-31-38 file INFO : 14/05/2016 6:32:04 > Unlocking phone... WARN : 14/05/2016 6:32:06 > Phone will restart now. Please don't disconnect cable! INFO : 14/05/2016 6:32:06 > Phone is successfully unlocked WARN : 14/05/2016 6:32:06 > To finish the operation, please restart the phone via phone's menu. INFO : 14/05/2016 6:32:11 > Performed by 2.2.6 software version Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\14-05-2016_18-28-08.log" closed (14/05/2016 6:36:29 ). I hope this can help you. |
05-16-2016, 00:36 | #5 (permalink) |
Member: 2188956 Status: Offline Thanks Meter: 29 | thank you everyone for helping it worked. Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G386T1 Reading info... Mode: Normal Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G386T1 Firmware compiled date: Wed Aug 6 00:06:25 KST 2014 PDA version: G386T1UVU1ANH3 CSC version: G386T1TMB1ANH3 SW version: G386T1UVU1ANH3 Phone IMEI: 352829069353601 Phone SN: R28G12FYJCW Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: afyonlteMetroPCS Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G386T1-15-05-2016_17-24-02 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version |
The Following User Says Thank You to truwrxtacy For This Useful Post: |
