Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-07-2015, 21:27   #1 (permalink)
anis_rainbow's Avatar
Member: 597569
Sonork: 100.1593870
Thanks Meter: 271
Thumbs up G530H unlock done
G530H unlock done
Welcome to Octoplus/Octopus Box Samsung software version 1.8.3
To connect SM-G530H phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM9
Selected model: SM-G530H
Reading info, please wait...
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: SM-G530H
Firmware compiled date: Wed Oct 22 18:18:16 KST 2014
PDA version: G530HXXU1ANJ4
CSC version: G530HODD1ANJ2
SW version: G530HDDU1ANJ1
Phone IMEI: 357213066507136
Phone SN: R51FC17KZ2R
Android version: 4.4.4 (KTU84P)
Selected port: COM9
Reading info...
Mode: Normal
Firmware compiled date: Oct 16 2014
Firmware compiled time: 22:00:00
Firmware released date: Oct 22 2014
Firmware released time: 15:16:00
SW Version: MPSS.DPM.1.0.c7.1-00045-M8916EAAAANVZM-
1.7069.1.7297.1
Reading QCN...
Send SPC...
Reading mobile property...
Mobile property read successfully
Reading feature mask...
Feature mask read successfully
Reading roaming list 0
Reading roaming list 0 read successfully
Reading NV items...
NV items read successfully
Reading NV SIM1 items...
NV SIM1 items read successfully
Reading NV SIM2 items...
NV SIM2 items read successfully
Reading NV items...
Reading EFS...
EFS read successfully
Reading provisioning items...
Provisioning items read successfully
Reading QCN done!
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SM-G530H-357213066507136-07-02-2015_20-55-
47-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
\BACKUP\Security-SM-G530H-357213066507136-07-02-2015_20-59-
23-.asec file
Wiping EFS...
EFS wipe successfully
Phone will restart now. Please don't disconnect cable!
Searching for a phone. Please wait...
Reading info...
Mode: Normal
1.7069.1.7297.1
Send SPC...
SPC send successfully
Writing QCN...
Writing NV items...
NV items write successfully
Writing NV SIM1 items...
NV SIM1 items write successfully
Writing NV SIM2 items...
NV SIM2 items write successfully
Wrting EFS...
EFS write successfully
Writing provisioning items...
Provisioning items write successfully.
Writing QCN done
Wipe security successfully complete.
Selected port: COM9
Selected file: C:\Documents and Settings\Administrator\My Documents
\Downloads\Compressed\Cert File\Cert_SM-G530H_
355677060467699.cert
Select Certificate2...
\Downloads\Compressed\Cert File\Cert-SM-G530H_00000001585678_
0000000000.cert
Powered on perform the following steps:
1. Connect phone via UART cable to the Box.
2. Note: phone screen must be active
Connecting to phone, please wait...
Found phone on COM9
Phone connected successfully
Checking Certificate file...
Certificate file successfully checked
Writing new phone IMEI...
Checking certificate compatibility...
Certificate is compatible
Writing Certificate...
Certificate has been written successfully
Please, restart the phone to apply changes
Old 02-07-2015, 21:39   #2 (permalink)
Member: 420870
Thanks Meter: 11
Hello
Does dis unlock gives super imei or the original one
Old 02-07-2015, 21:41   #3 (permalink)
Member: 597569
Sonork: 100.1593870
Thanks Meter: 271
No its not original imei after write certificate imei will be change ok
Old 02-08-2015, 08:00   #4 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 263
what cert did you use?
Old 02-08-2015, 10:50   #5 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Hello,
you can check cert name in his logs. Also You Can Find It On Support Server...
Regards,
Page generated in 0.15911 seconds with 8 queries
