02-24-2017, 18:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | g550t1 frp successfully removed by octoplus Welcome to Octoplus/Octopus Box Samsung software version 2.4.8 ----------------------------------------------------------------------------------- To connect SM-J120A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G550T1 Reset FRP/ Reactivation lock operation for SM-G550T1 will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G550T1 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.4.8 Software version. Last edited by Octopus box; 02-24-2017 at 20:42. |
The Following User Says Thank You to ziggywong0305 For This Useful Post: |
02-24-2017, 18:41 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | Octoplus/Octopus Samsung Factory Services v.2.4.8 ----------------------------------------------------------------------- Connecting to server..OK Username: pXXXXXXXXXXXXXXXe Authorization..OK Checking smart card... Smart card successfully checked. Checking balance..OK Your balance: XXX credits. Requesting history..OK History successfully obtained! ----------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Found device on COM38 Reading info... Detected device model: SM-G930F HW Version: SM-G930FZKAH3G PDA version: G930FXXS1BPK6 CSC version: G930FH3G1BPI1 CP version: G930FXXU1BPJE Device SN: RXXXXXXXXXE Device IMEI: 3XXXXX-07-XXXXXX-2 FRP/Reactivation: TRIGGERED Connecting to server..OK Username: pXXXXXXXXXXXe Authorization..OK Checking smart card... Smart card successfully checked. Checking balance..OK Your balance: XXX credits. Sending device information..OK Checking operation...OK Checking data..OK Reading FRP/Reactivation lock data.. Service is busy! Please try again later! regards MINT CENTRE... |
