12-14-2016, 08:30 | #1 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | g570f frp problem need help ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected AP file: G:\samsung combination file \COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2 \COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2 \COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2_CL955 5172 _QB11274596_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.4.6 Software version. |
12-14-2016, 09:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. There are two methods, of how to reset FPR using Combination firmware on phones with latest firmwares: I.
II.
Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, necessary files are missing, or You don't want to take risk - You can use Factory Reset FRP Service. |
12-20-2016, 08:44 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Unfortunately not all Combination firmware contain "Enable OEM unlocking" option. You can either try to use I method, or to use another Combination firmware. |
