09-06-2019, 10:38 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | g610f frp urt [Answered] g610f lot of frp i done via urt method but in this latest update Welcome to Octoplus Box Samsung software version 2.8.2 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. Platform: Samsung Android Selected port: COM16 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. |
09-06-2019, 11:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to use our Factory Reset FRP Service. For more detail information and prices, please check Credits consumption II. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. III. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. IV. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! Please, remove card from box, clean all contacts, insert back into box and try to update card again, if problem still remain, remove card from box, insert into another card reader, dongle and try to update card, if You still have problem most likely your card is damaged via third party Software. |
09-06-2019, 11:56 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | As i can see from the Sofware log: UART interfaces not found! Please, check Device manager and make sure that com port of box is present |
09-07-2019, 06:29 | #4 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | team as i said i done lot of device via urt method, but this time its fail, its your update fault becoz in old device your sw 1st need usb connected then another screen will aprear for guide press power & vol button etc,,, but in this case when you press reset frp via urt its directly show this log Platform: Samsung Android Selected port: COM4 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.8.2 Software version. even within second, well i done with another method but kindly check and fix it, |
