11-26-2016, 14:00 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 274436 Status: Offline Thanks Meter: 26 | SM-G610F unlock problem [Solved] Selected port: COM82 Selected model: SM-G610F Detected phone model: SM-G610F Firmware compiled date: Tue Oct 18 16:40:06 KST 2016 PDA version: G610FDXU1APJ4 CSC version: G610FOLB1API5 SW version: G610FDDU1APJ3 Phone SN: R58HA5Y2G6A Android version: 6.0.1 (MMB29K) Sales code: XME Country: MALAYSIA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2016-10-01 Codename: on7xeltedd Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Executing exploit failed Read codes failed Performed by 2.4.5 Software version. Last edited by Octopus box; 04-04-2018 at 12:59. |
11-26-2016, 14:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please download and install "install_octoplus_octopus_Samsung_2.4.5.2" Software from "samsung/TEST SOFTWARE" folder of the Support Area. Repeat "Read Codes" operation and post here the result. |
11-27-2016, 10:20 | #3 (permalink) |
Guest
Posts: n/a
Member: | Welcome to Octoplus/Octopus Box Samsung software version 2.4.5 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G610F Detected phone model: SM-G610F Firmware compiled date: Thu Aug 25 00:51:06 KST 2016 PDA version: G610FDDU1APHD CSC version: G610FOJV1APH6 SW version: G610FDDU1API4 Phone SN: RZ8H91Y406Y Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2016-09-01 Codename: on7xeltedd Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Exploit has been executed successfully Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 03581816 NET LOCK unlock code: 26150717 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:11 Performed by 2.4.5 Software version. |
04-04-2018, 12:39 | #5 (permalink) |
Freak Poster Join Date: Apr 2015 Location: @kilinochchi, Sri Lanka
Member: 2372779 Status: Offline Sonork: 100.1680276 Thanks Meter: 33 | Samsung SM-G610F Flashing Error Hi Octoplus Team Phone not booting wen i on the phone Samsung log and Custom bynery Blocked by FRP Lock then try to flash with Sammobile Firmware not successfully then try with Octoplus Firmware same status Ocoplus Logs Welcome to Octoplus Box Samsung software version 2.6.6 Selected firmware file: G610FDDU1APHD_G610FOJV1API2 _ACR_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G610F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 2.6.6 Software version. phone Status image |
04-04-2018, 13:01 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As I see from your posted photo and Software log, your device model is SM-G610F, but You try to write firmware for SM-G610FD. Please try to write correct firmware. |
04-04-2018, 13:14 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, thanks for report, probably firmware was uploaded to this folder by mistake. We will remove it. Try to write other firmwares for SM-G610F. |
04-04-2018, 13:20 | #9 (permalink) |
Member: 2372779 Status: Offline Sonork: 100.1680276 Thanks Meter: 33 | Hello Octplus I was Try with another Firmware From Sammobile but result is same that firmware as 4 files how t fix it please |
04-04-2018, 13:31 | #12 (permalink) |
Member: 2372779 Status: Offline Sonork: 100.1680276 Thanks Meter: 33 | Selected BOOT file: C:\Users\Rock\Desktop\G610FDDU1BQL9 _G610FOJV1BQL2_XSG\BL_G610FDDU1BQL9_CL12721818 _QB16169621_REV00_user_low_ship.tar.md5 Selected AP file: C:\Users\Rock\Desktop\G610FDDU1BQL9 _G610FOJV1BQL2_XSG\AP_G610FDDU1BQL9_CL12721818 _QB16169621_REV00_user_low_ship_meta.tar.md5 Selected CP file: C:\Users\Rock\Desktop\G610FDDU1BQL9 _G610FOJV1BQL2_XSG\CP_G610FDDU1BQJ4_CP7763425 _CL12417615_QB15304404_REV00_user_low_ship.tar.md5 Selected CSC file: C:\Users\Rock\Desktop\G610FDDU1BQL9 _G610FOJV1BQL2_XSG\CSC_OJV_G610FOJV1BQL2_CL1270572 0 _QB16127757_REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G610F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 2.6.6 Software version. |
04-04-2018, 14:17 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, try to reflash your device with "G610FXXU1APK1_G610FODI1APK1_INS_Android_6.0.1 " firmware from the Support Area, then post here full Software log. Also, we have uploaded new firmware into the Support Area for SM-G610F, please try to reflash the phone with that firmware Last edited by Octopus box; 04-04-2018 at 14:28. |
