11-11-2014, 17:17 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2161676 Status: Offline Thanks Meter: 7 | G7102T repair imei |
11-11-2014, 17:32 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Repair IMEI for G7102T is currently not supported: http://forum.gsmhosting.com/vbb/10661361-post1.html: Quote:
Try to write firmwares for SM-G7102T. We will upload firmwares for SM-G7102T for You into the Support Area in 1-2 hours. | |
02-13-2015, 07:24 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | What is the firmware's Android version now in your device? Please read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
02-13-2015, 16:05 | #6 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Brasil
Member: 543573 Status: Offline Thanks Meter: 9 | Androide 4.3. Board new. Direct fron Sam and the phone is with Samsung engineering settings. Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102T Reading info, please wait... ADB server killed. Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: FA43_G7102TVJUANC1 CSC version: Unknown Versão do SW: G7102TVJUANC1 |
02-13-2015, 16:16 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Currently we have no this device in hands, so, we can't research and develop the solution for it. You can try to write modem file for SM-G7102 "sm-g7102_special_modem_to_repair_any_imei_4_3" from the Support Area for your own risk and then connect the phone as SM-G7102, make Wipe Security and write any IMEI. |
02-13-2015, 16:53 | #8 (permalink) |
Member: 543573 Status: Offline Thanks Meter: 9 | Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Warning: Selected model (SM-G7102) differs from the detected one (SM-G7102T)! If you want select (SM-G7102T) as (SM-G7102) model, please check "manual select". Reading info... No porto seleccionado o telefone não foi detectado! ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM8 Modelo seleccionado: SM-G7102 Warning: Selected model (SM-G7102) differs from the detected one (SM-G7102T)! If you want select (SM-G7102T) as (SM-G7102) model, please check "manual select". Reading info... No porto seleccionado o telefone não foi detectado! ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: Unknown CSC version: Unknown Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15Q) Reading info... No porto seleccionado o telefone não foi detectado! ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: Unknown CSC version: Unknown Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15Q) Reading info... No porto seleccionado o telefone não foi detectado! ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: Unknown CSC version: Unknown Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15Q) Checking Root: Phone is Rooted. IMEI antigo: Unknown Novo IMEI: 352166-06-058103-3 Repairing IMEI A... Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: Unknown CSC version: Unknown Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15Q) Checking Root: Phone is Rooted. IMEI antigo: Unknown Novo IMEI: 352166-06-058103-3 Repairing IMEI A... Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102 Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Mon Mar 17 16:53:51 KST 2014 PDA version: Unknown CSC version: Unknown Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15Q) Checking Root: Phone is Rooted. IMEI antigo: Unknown Novo IMEI: 352167-06-085103-8 Repairing IMEI B... Write IMEI failed |
02-13-2015, 17:01 | #9 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Unfortunately, as You can see, this modem firmware is not suitable for your phone: Quote:
02-13-2015, 18:18 | #10 (permalink) | |
Member: 543573 Status: Offline Thanks Meter: 9 | Quote:
Where can I found imei certificate for this? | |
02-13-2015, 18:52 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Unfortunately, currently no solution, how to read out IMEI Certificates from devices, which are based on Qualcomm CPUs. |
