06-02-2014, 21:55 | #3 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Addis ababa
Member: 1002335 Status: Offline Sonork: 175 Thanks Meter: 9 | the imei is ok after unlock Platform: Samsung Android Selected port: COM322 Selected model: SM-G730A Mode: Normal Phone model: SM-G730A Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 21 2013 Firmware released time: 14:14:15 Phone IMEI: 357130-05-073847-9 SW version: M8930B-AAAATAZM-5.0.060077 Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Wed Aug 21 13:27:12 KST 2013 PDA version: G730AUCUAMH4 CSC version: G730AATTAMH4 SW version: G730AUCUAMH4 Phone IMEI: 357130050738479 Phone SN: R31D81HA57B Android version: 4.2.2 (JDQ39) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G730A-357130050738479-02-06-2014_15-51-29-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 21 2013 Firmware released time: 14:14:15 Incorrect IMEI SW version: M8930B-AAAATAZM-5.0.060077 Found phone on COM322 Repairing NVM for SM-G730A phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
06-03-2014, 06:38 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to make Repair IMEI, then insert SIM card, wait 3-5 minutes and check whether the network is active. Also try to re-flash the device with the firmware from the Support Area, then perform "Repair NVM" operation once again, insert SIM card, wait 3-5 minutes and check whether the network is active. |
06-03-2014, 07:49 | #5 (permalink) |
Member: 1002335 Status: Offline Sonork: 175 Thanks Meter: 9 | Platform: Samsung Android Selected port: COM156 Selected model: SM-G730A Mode: Normal Phone model: SM-G730A Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 21 2013 Firmware released time: 14:14:15 Phone IMEI: 357130-05-073847-9 SW version: M8930B-AAAATAZM-5.0.060077 Creating NVM backup Reading NVM done! Repairing NVM for SM-G730A phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
06-03-2014, 08:34 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from this Software log, Software can't perform Repair NVM operation. This can be the problem. Please do the next: 1. Install the latest Software version (Software). 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Run Octoplus Samsung Software. 4. Re-start the phone. 5. Perform "Repair NVM" operation. 6. Close the Software. 7. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" together with all NVM backups from this phone, which have been created by Software, from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\" and post here links, we will research, where can be the problem with your device. |
06-03-2014, 09:36 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Re-flash the device with the firmware from the Support Area, then perform "Repair NVM" operation once again and post here the result. |
06-03-2014, 10:02 | #12 (permalink) |
Member: 1002335 Status: Offline Sonork: 175 Thanks Meter: 9 | Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\03-06-2014_11-27-59.log" created (6/3/2014 11:28:02 AM). ERROR : 6/3/2014 11:28:02 AM > Access violation at address 008F42F8 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 6/3/2014 11:28:03 AM > Set up system language English (file: English.ini) INFO : 6/3/2014 11:28:03 AM > Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 INFO : 6/3/2014 11:28:03 AM > ----------------------------------------------------------------------------------- INFO : 6/3/2014 11:28:03 AM > To connect SM-G730A phone you have to perform the following steps: INFO : 6/3/2014 11:28:03 AM > 1. Disconnect USB cable from phone. INFO : 6/3/2014 11:28:03 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/3/2014 11:28:03 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/3/2014 11:28:03 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/3/2014 11:28:03 AM > 5. Turn on "USB Debugging" option. INFO : 6/3/2014 11:28:03 AM > 6. Go to dial window. INFO : 6/3/2014 11:28:03 AM > 7. Enter "*#0808#" number. INFO : 6/3/2014 11:28:03 AM > 8. Select "DM+Modem+ADB". INFO : 6/3/2014 11:28:03 AM > 9. Press Home button. INFO : 6/3/2014 11:28:03 AM > 10. Go to dial window. INFO : 6/3/2014 11:28:03 AM > 11. Enter "*#9090#" number. INFO : 6/3/2014 11:28:03 AM > 12. Set "Diag config" to "USB" value. INFO : 6/3/2014 11:28:03 AM > 13. Restart phone. INFO : 6/3/2014 11:28:03 AM > 14. Press "Read Info" in software. INFO : 6/3/2014 11:43:27 AM > Selected firmware file: G730AUCUAMH4_G730AATTAMH4_ATT_Android_4.2.2.oct WARN : 6/3/2014 11:43:30 AM > Please switch your phone to the download mode and connect it to a PC. WARN : 6/3/2014 11:43:30 AM > To put SM-G730A phone into download mode you have to perform the following steps: WARN : 6/3/2014 11:43:30 AM > 1. Reconnect phone battery. WARN : 6/3/2014 11:43:30 AM > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 6/3/2014 11:43:30 AM > 3. When phone turns on press "Volume+" button. INFO : 6/3/2014 11:43:50 AM > Found phone on INFO : 6/3/2014 11:43:50 AM > Firmware write started. INFO : 6/3/2014 11:43:51 AM > Writing BOOT section... INFO : 6/3/2014 11:43:54 AM > BOOT section has been written successfully. INFO : 6/3/2014 11:43:54 AM > Writing RECOVERY section... INFO : 6/3/2014 11:43:58 AM > RECOVERY section has been written successfully. INFO : 6/3/2014 11:43:58 AM > Writing SYSTEM section... INFO : 6/3/2014 11:46:47 AM > SYSTEM section has been written successfully. INFO : 6/3/2014 11:46:47 AM > Writing MODEM section... INFO : 6/3/2014 11:46:59 AM > MODEM section has been written successfully. INFO : 6/3/2014 11:46:59 AM > Writing CACHE section... INFO : 6/3/2014 11:47:10 AM > CACHE section has been written successfully. INFO : 6/3/2014 11:47:10 AM > Writing HIDDEN section... INFO : 6/3/2014 11:47:13 AM > HIDDEN section has been written successfully. INFO : 6/3/2014 11:47:13 AM > Firmware writing successfully completed. INFO : 6/3/2014 11:59:51 AM > Platform: Samsung Android INFO : 6/3/2014 11:59:51 AM > Selected port: COM156 INFO : 6/3/2014 11:59:51 AM > Selected model: SM-G730A INFO : 6/3/2014 11:59:51 AM > Mode: Normal INFO : 6/3/2014 11:59:52 AM > Phone model: SM-G730A INFO : 6/3/2014 11:59:52 AM > Firmware compiled date: Jul 09 2013 INFO : 6/3/2014 11:59:52 AM > Firmware compiled time: 05:00:00 INFO : 6/3/2014 11:59:52 AM > Firmware released date: Aug 21 2013 INFO : 6/3/2014 11:59:52 AM > Firmware released time: 14:14:15 INFO : 6/3/2014 11:59:52 AM > Phone IMEI: 357130-05-073867-7 INFO : 6/3/2014 11:59:52 AM > SW version: M8930B-AAAATAZM-5.0.060077 INFO : 6/3/2014 11:59:52 AM > Creating NVM backup INFO : 6/3/2014 12:00:28 PM > Reading NVM done! INFO : 6/3/2014 12:00:28 PM > Repairing NVM for SM-G730A phone... ERROR : 6/3/2014 12:00:28 PM > Writing NVM failed INFO : 6/3/2014 12:00:28 PM > NVM repair completed successfully WARN : 6/3/2014 12:00:28 PM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
06-03-2014, 10:26 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Was your device locked at the beginning? Did the phone request the unlocking code when you inserted SIM card or just the problem was with network access? |
06-03-2014, 10:35 | #14 (permalink) |
Member: 1002335 Status: Offline Sonork: 175 Thanks Meter: 9 | Before I do the unlock process the phone was asking for a code and there was a network signal after the process the network sign changed to no service |
06-03-2014, 11:00 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to do the next: 1. Write the first security backup (that has been created by Software before You have performed the first Unlock operation). 2. Re-flash the phone. 3. Perform the Unlock operation once again. |
