08-04-2015, 16:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | g800y cert write problem cant write cert file *#7284# not working below the details Welcome to Octoplus/Octopus Box Samsung software version 1.9.9 ----------------------------------------------------------------------------------- To connect SM-G800Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G800Y Selected file: C:\Users\Prabha Ent\Downloads\cert-sm-g800y_ 354481065051157_r58f91kvvk.cert Detected phone model: SM-G800Y Firmware compiled date: Tue Mar 31 20:39:36 KST 2015 PDA version: G800YDVU1AOC2 CSC version: G800YTLP1AOB1 SW version: G800YDVU1AOC3 Phone IMEI: 350695200123951 Phone SN: R58G41VVP7R Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G800Y-Unknown04-08-2015_20-14-44-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G800Y Selected file: C:\Users\Prabha Ent\Downloads\cert-sm-g800y_ 354481065051157_r58f91kvvk.cert Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G800Y Firmware compiled date: Tue Mar 31 20:39:36 KST 2015 PDA version: G800YDVU1AOC2 CSC version: G800YTLP1AOB1 SW version: G800YDVU1AOC3 Phone IMEI: 350695200123951 Phone SN: R58G41VVP7R Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G800Y-Unknown04-08-2015_20-27-00-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G800Y Reading info, please wait... Detected phone model: SM-G800Y Firmware compiled date: Tue Mar 31 20:39:36 KST 2015 PDA version: G800YDVU1AOC2 CSC version: G800YTLP1AOB1 SW version: G800YDVU1AOC3 Phone IMEI: 350695200123951 Phone SN: R58G41VVP7R Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G800Y Selected file: C:\Users\Prabha Ent\Downloads\cert-sm-g800y_ 354481065051157_r58f91kvvk.cert Detected phone model: SM-G800Y Firmware compiled date: Tue Mar 31 20:39:36 KST 2015 PDA version: G800YDVU1AOC2 CSC version: G800YTLP1AOB1 SW version: G800YDVU1AOC3 Phone IMEI: 350695200123951 Phone SN: R58G41VVP7R Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G800Y-Unknown04-08-2015_21-06-42-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed please support best regards |
08-04-2015, 17:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
08-05-2015, 08:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | There is no need to make changes in *#7284# menu, to connect the phone. If You have blocked the battery pin, but problem remains the same, try to re-install FTDI Drivers, try to use different Samsung C3300k/C3303k micro UART cables with 525-530kOm resistor, try to use another box as UART interface. |
