12-10-2014, 17:19 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: MKD Age: 40
Member: 939467 Status: Offline Thanks Meter: 50 | g850f can't connect to factory unlock [Solved] I have problem in connecting G850F for factory unlock with UART cable.. I have unlocked I9505 with same cable 5 min ago but this one is just not recognized by box.. phone is brand new.. Any advice? Regards, Last edited by Octopus box; 12-11-2014 at 14:33. |
12-10-2014, 17:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Please block highlighted pin with a tape and try to connect the phone via Samsung Micro UART C3300k/C3303k cable with 523-525kOhm resistor. |
12-10-2014, 17:46 | #3 (permalink) | |
Member: 939467 Status: Offline Thanks Meter: 50 | Quote:
Phone is still locked and 00000000 code did not pass here is the log: Welcome to Octoplus/Octopus Box Samsung software version 1.7.7 ----------------------------------------------------------------------------------- To connect SM-G850F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Connecting to server... Username: xxxxxxxxxx Authorizing... Checking balance... Your balance: 41 credits. ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM3 Reading info... Phone model: SM-G850F Phone IMEI: 35521006149234 MSL address: RF8F9120SC Requesting MSL code... Connecting to server Username: xxxxxxxxxxx Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 41 credits. Checking request.. Sending request... Order ID: 69317 MSL code has been obtained successfully! Deactivating MSL... MSL deactivate successfully Unlocking phone... Factory Unlock operation successfully completed! To unlock please type '00000000' (8 zeros). Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Connecting to server... Username: xxxxxxxxxxxx Authorizing... Checking balance... Your balance: 32 credits. ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM3 Reading info... Phone model: SM-G850F Phone IMEI: 35521006149234 MSL address: RF8F9120SC Requesting MSL code... Connecting to server Username: xxxxxxxxxxx Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 32 credits. Checking request.. Order ID: 69317 MSL code has been obtained successfully! Deactivating MSL... MSL deactivate successfully Unlocking phone... Factory Unlock operation successfully completed! To unlock please type '00000000' (8 zeros). Please, restart the phone to apply changes I turn off the phone from menu (don't unplug the battery) Phone request's unlock code.. I enter 00000000 but I get phone unlocked unsucessfully Any hint? | |
12-10-2014, 19:22 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please upload *.log and *.logx files of "Factory Unlock" operation and post here download link. We will check where can be the problem. |
12-10-2014, 19:36 | #7 (permalink) | |
log files - Download - 4shared | |
12-11-2014, 14:00 | #9 (permalink) |
Member: 939467 Status: Offline Thanks Meter: 50 | solved it finnaly with the help of support of course just install the older version of samsung tool 1.7.6 unlock worked like charm thanks |
The Following User Says Thank You to Akvarius_Sistem For This Useful Post: |
