06-24-2017, 06:11 | #1 (permalink) |
Junior Member Join Date: Sep 2014 Location: san diego
Member: 2261644 Status: Offline Thanks Meter: 2 | g890a frp bypass before i could flash engineering bootlaoder, and then remove through octopus, now it flashes something, reboots, and the phone states it has no space, and if i go to factory reset in settings it asks for samsung account, even entering samsung account, will still not do it. octopus flashes the file fine, and it boots up, but many programs crash, and says memory error. is there an option to use old method? thanks -mario |
06-24-2017, 08:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. To remove Samsung Account You need to do the next: 1. Create new Samsung account (via PC or via another phone). You should have working Samsung Account. 2. Perform the "Reset FRP/ Reactivation" operation. 3. When FRP lock will be successfully reseted, wait 3-4 minutes, then go to "Backup and reset" and try to make "Factory data reset" - the phone will ask You to enter Samsung account data - enter Samsung account data, which You have created earlier. If "Factory data reset can"t be done via phone"s menu, try to make "Factory data reset" via Recovery mode ("wipe data/factory reset"). 4. Restart the phone and connect it to Wi-Fi. 5. Go to https://findmymobile.samsung.com/ and log in with the username and password (which You have created earlier). In there select the phone that it just added to account, select "Unlock my device" and "Unlock Reactivation lock". |
06-24-2017, 19:06 | #3 (permalink) | |
Member: 2261644 Status: Offline Thanks Meter: 2 | Quote:
i have been able to add samsung account once, but upon factory reset through recovery, i could not find it on samsung site (it would show the phone but not give option to unlock) now i cant even log into samsung because it will crash when i hit next. | |
06-26-2017, 07:30 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to refash the phone and check whether it works stable. After this - try to perform steps 1-5, described in previous post. |
06-28-2017, 00:11 | #5 (permalink) |
Member: 2261644 Status: Offline Thanks Meter: 2 | i have tried both 6.0 and 7.0, neither produce stable results after flashing the frp unlock in downloadmode. reseting the phone with original firmware prompts for samsung account. |
06-28-2017, 07:57 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If phone works correctly after writing of a firmware (it doesn't force close and there's no more errors) - try to repeat the whole process, described in previous post (steps 1-5). |
06-30-2017, 00:11 | #7 (permalink) | |
i tried 5.0, wiped everything performed frp bypass phone is buggy 6.0, wipe phone, flash frp bypass, phone is buggy flash 7.0, frp bypass, phone is buggy. each time it says the phone is out of space and the space gets filled up (right after i flash the bypass). is there a way to use the old method where i flash the sboot and it wipes the frp/samsung reactivation. because after i do a factory reset, samsung account is there waiting, and now samsungs find my mobile says registration incomplete when and if i manage to sign in. | |
06-30-2017, 07:31 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | After "Reset FRP/ Reactivation" operation You need to use previously created, new Samsung account. Please carefully read the steps, required to remove the lock. |
07-02-2017, 01:56 | #9 (permalink) | |
I just told you I can't register the phone w Samsung because everything crashes. And when I do it doesn't show up on find my mobile... It says processing may take a few days... Its been 2 weeks. Again this solution bugs the phone so its not possible to enter Samsung account. I know what steps you want me to take... They can't be done as you say. | |
07-03-2017, 07:41 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If phone doesn't appear on findmymobile site after You enter an account - it is not possible to remove Reactivation Lock from such device at the moment. |
07-06-2017, 07:35 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Old method was removed, because it was working only for devices with old firmwares (old type of Security) and downgrading is not possible. |
