02-06-2015, 08:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | g900f reseau probleme repair security wipe security write cert write qcn Platform: Samsung Android Selected port: COM31 Selected model: SM-G900F Selected file: C:\Documents and Settings\adel\Bureau\Nouveau dossier (2)\Cert-SM-G900F_352558067456427_00000000000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: 352558067456401 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM31 Selected model: SM-G900F Selected file: C:\Documents and Settings\adel\Bureau\Cert-SM- G900F_CERT_352558068274001.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: 352558067456427 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM31 Selected model: SM-G900F Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: 352558067456427 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900F-352558067456427-06-02-2015_08-22- 00-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900F-352558067456427-06-02-2015_08-27- 06-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! same probleme |
02-06-2015, 08:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next: 1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security. 4. When the IMEI becomes "Unknown", Write Certificate. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10681731, http://forum.gsmhosting.com/vbb/f684.../#post10705160, http://forum.gsmhosting.com/vbb/f684.../#post10708907. |
02-06-2015, 10:51 | #3 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | same probleme Welcome to Octoplus/Octopus Box Samsung software version 1.8.3 ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: 352558067456427 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900F-352558067456427-06-02-2015_10-27- 18-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900F-352558067456427-06-02-2015_10-31- 27-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Selected file: C:\Documents and Settings\adel\Bureau\Nouveau dossier (5)\Cert-SM-G900F_352558067456401_00000000000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Selected file: C:\Documents and Settings\adel\Bureau\Nouveau dossier (5)\Cert-SM-G900F_352558067456419_00000000000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Dec 1 22:58:47 KST 2014 PDA version: G900FXXU1ANL1 CSC version: G900FOJV1AOA1 SW version: G900FXXU1ANG8 Phone IMEI: 352558067456401 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes |
02-06-2015, 11:00 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see, "Wipe Security" operation was no performed successfuly,: Quote:
In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next: 1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security. 4. When the IMEI becomes "Unknown", Write Certificate. Look here: http://forum.gsmhosting.com/vbb/f684.../#post10841545. | |
