10-16-2016, 15:39 | #1 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | G900F Unlock Done But Still Locked [Solved] G900F Unlock Done But Still Locked Fast Unlock Operation Not Supported Octopus Team Help Me.... Screenshots:: Log Here:: Quote:
10-16-2016, 19:40 | #2 (permalink) |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Bro you need to downgrade to PC2 Firmware. If you can't because is to older and the phone dont let you, then try to downgrade only modem and try again (This last option is at your own risk). I recomend try to downgrade. This not will kill your phone. I know that in PC2 firmware you can unlock with octoplus |
The Following User Says Thank You to Alexandroid For This Useful Post: |
10-16-2016, 20:16 | #3 (permalink) | |
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Hi Quote:
Downgrade To 5.1 or 5.0? & Which version , kindly tell me.... | |
10-16-2016, 23:45 | #4 (permalink) | |
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
You need downgrade to G900FXXU1CPD3_G900FVFR1CPC2 Try this https://androidfilehost.com/?fid=4996500813288309447 In this 6.0.1 you can unlock with octoplus with fast unlock. Is not necesary to be root. | |
10-17-2016, 08:37 | #5 (permalink) | |
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | G900F Android Ver 6.0.1 Fast Unlock Done G900F Android Ver 6.0.1 Fast Unlock Done this unlock problem solved by downgrade to phone 5.0.... Go To Support & Download This Version... Code: G900FXXU1BOC7_G900FOXA1BOC7_BTU_Android_5.oct Then flash With octopus box Code: INFO : 10/17/2016 11:36:44 AM > To connect SM-G900F phone you have to perform the following steps: INFO : 10/17/2016 11:36:44 AM > 1. Disconnect USB cable from phone. INFO : 10/17/2016 11:36:44 AM > 2. Go to Menu->Settings->More->About Device. INFO : 10/17/2016 11:36:44 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 10/17/2016 11:36:44 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 10/17/2016 11:36:44 AM > 5. Turn on "USB Debugging" option. INFO : 10/17/2016 11:36:44 AM > 6. Go to dial window. INFO : 10/17/2016 11:36:44 AM > 7. Enter "*#0808#" number. INFO : 10/17/2016 11:36:44 AM > 8. Select "DM+Modem+ADB". INFO : 10/17/2016 11:36:44 AM > 9. Press Home button. INFO : 10/17/2016 11:36:44 AM > 10. Restart phone. INFO : 10/17/2016 11:36:44 AM > 11. Press "Read Info" in software. INFO : 10/17/2016 11:38:05 AM > Selected firmware file: G900FXXU1BOC7_G900FOXA1BOC7_BTU_Android_5.oct WARN : 10/17/2016 11:38:14 AM > Please put the phone into Download Mode and connect USB cable. WARN : 10/17/2016 11:38:14 AM > To put SM-G900F into Download Mode, You have to perform the following steps: WARN : 10/17/2016 11:38:14 AM > 1. Reconnect the battery. WARN : 10/17/2016 11:38:14 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/17/2016 11:38:14 AM > 3. When phone turns on, press "Volume+" key. INFO : 10/17/2016 11:38:15 AM > Writing firmware Canceled INFO : 10/17/2016 11:38:15 AM > Performed by 2.3.8 Software version. WARN : 10/17/2016 11:38:17 AM > Please put the phone into Download Mode and connect USB cable. WARN : 10/17/2016 11:38:17 AM > To put SM-G900F into Download Mode, You have to perform the following steps: WARN : 10/17/2016 11:38:17 AM > 1. Reconnect the battery. WARN : 10/17/2016 11:38:17 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/17/2016 11:38:17 AM > 3. When phone turns on, press "Volume+" key. INFO : 10/17/2016 11:38:19 AM > Writing firmware Canceled INFO : 10/17/2016 11:38:19 AM > Performed by 2.3.8 Software version. WARN : 10/17/2016 11:38:21 AM > Please put the phone into Download Mode and connect USB cable. WARN : 10/17/2016 11:38:21 AM > To put SM-G900F into Download Mode, You have to perform the following steps: WARN : 10/17/2016 11:38:21 AM > 1. Reconnect the battery. WARN : 10/17/2016 11:38:21 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/17/2016 11:38:21 AM > 3. When phone turns on, press "Volume+" key. INFO : 10/17/2016 11:38:39 AM > Found phone on INFO : 10/17/2016 11:38:39 AM > Firmware write started. INFO : 10/17/2016 11:38:39 AM > Writing ABOOT section... INFO : 10/17/2016 11:38:41 AM > ABOOT section has been written successfully. INFO : 10/17/2016 11:38:41 AM > Writing SBL1 section... INFO : 10/17/2016 11:38:44 AM > SBL1 section has been written successfully. INFO : 10/17/2016 11:38:44 AM > Writing RPM section... INFO : 10/17/2016 11:38:46 AM > RPM section has been written successfully. INFO : 10/17/2016 11:38:46 AM > Writing TZ section... INFO : 10/17/2016 11:38:48 AM > TZ section has been written successfully. INFO : 10/17/2016 11:38:48 AM > Writing DBI section... INFO : 10/17/2016 11:38:50 AM > DBI section has been written successfully. INFO : 10/17/2016 11:38:50 AM > Writing APNHLOS section... INFO : 10/17/2016 11:38:53 AM > APNHLOS section has been written successfully. INFO : 10/17/2016 11:38:53 AM > Writing BOOT section... INFO : 10/17/2016 11:38:56 AM > BOOT section has been written successfully. INFO : 10/17/2016 11:38:56 AM > Writing RECOVERY section... INFO : 10/17/2016 11:38:59 AM > RECOVERY section has been written successfully. INFO : 10/17/2016 11:38:59 AM > Writing SYSTEM section... INFO : 10/17/2016 11:43:07 AM > SYSTEM section has been written successfully. INFO : 10/17/2016 11:43:07 AM > Writing CACHE section... INFO : 10/17/2016 11:43:12 AM > CACHE section has been written successfully. INFO : 10/17/2016 11:43:12 AM > Writing HIDDEN section... INFO : 10/17/2016 11:43:15 AM > HIDDEN section has been written successfully. INFO : 10/17/2016 11:43:15 AM > Writing MODEM section... INFO : 10/17/2016 11:43:23 AM > MODEM section has been written successfully. INFO : 10/17/2016 11:43:23 AM > Firmware writing successfully completed. INFO : 10/17/2016 11:43:23 AM > Performed by 2.3.8 Software version. Log Here:: Quote:
All Problem Solved.... Last edited by tapas770; 10-17-2016 at 08:43. | |
