01-16-2017, 08:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: karachi
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | G900H cert read failed [Solved] ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900H Firmware compiled date: Thu Oct 20 22:02:36 KST 2016 PDA version: G900HXXS1CPJ9 CSC version: G900HOJV1CPF1 SW version: G900HXXU1CPCA Phone SN: R21F4203R2P Android version: 6.0.1 (MMB29K) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos5422 HW Modem: XMM6360 Security patch level: 2016-10-01 Codename: k3gxx Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Reading Certificate failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Detected phone model: SM-G900H Firmware compiled date: Thu Oct 20 22:02:36 KST 2016 PDA version: G900HXXS1CPJ9 CSC version: G900HOJV1CPF1 SW version: G900HXXU1CPCA Phone SN: R21F4203R2P Android version: 6.0.1 (MMB29K) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos5422 HW Modem: XMM6360 Security patch level: 2016-10-01 Codename: k3gxx Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Reading Certificate failed Performed by 2.4.7 Software version. i try without sim card still failed Last edited by Octopus box; 01-16-2017 at 16:01. |
01-16-2017, 09:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please download and install from the Support Area ("SAMSUNG/TEST_SOFTWARE" folder) the latest test Software version, then repeat "Read Cert" operation again. Post here full Software log. |
01-16-2017, 10:12 | #3 (permalink) | |
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | Quote:
----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Detected phone model: SM-G900H Firmware compiled date: Thu Oct 20 22:02:36 KST 2016 PDA version: G900HXXS1CPJ9 CSC version: G900HOJV1CPF1 SW version: G900HXXU1CPCA Phone SN: R21F4203R2P Android version: 6.0.1 (MMB29K) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos5422 HW Modem: XMM6360 Security patch level: 2016-10-01 Codename: k3gxx Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Reading Certificate failed i try SAMSUNG/TEST_SOFTWARE" folder latest software still failed | |
01-16-2017, 10:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload the following files to any file-sharing service: 1. Security backup of the phone. You can make a backup via "Read Security" operation. 2. *.log and *.logx files of performed operations. Files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Post here download link for these 3 files and we will check where can be the problem with your device. Last edited by Octopus box; 01-16-2017 at 10:43. |
01-16-2017, 10:54 | #5 (permalink) | |
01-16-2017, 11:15 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | *.log" and "*.logx" files, which You have uploaded, don't contains "Read Cert" operation. Please repeat "Read Cert" operation, close Software and upload new created *.log" and "*.logx" files with "Read Cert" procedure. |
01-16-2017, 11:37 | #7 (permalink) | |
01-16-2017, 12:21 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You've uploaded incorrect "*.logx" file. Please upload "*.logx" file with the same name (title) as "*.log" file. Last edited by Octopus box; 01-16-2017 at 12:27. |
01-16-2017, 12:33 | #9 (permalink) | |
01-16-2017, 13:36 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please contact us to Skype, or Yahoo! Messenger, we'll check where can be the problem with your phone. Our contacts You can find in our profile. |
01-16-2017, 15:56 | #11 (permalink) |
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Detected phone model: SM-G900H Firmware compiled date: Thu Oct 20 22:02:36 KST 2016 PDA version: G900HXXS1CPJ9 CSC version: G900HOJV1CPF1 SW version: G900HXXU1CPCA Phone SN: R21F4203R2P Android version: 6.0.1 (MMB29K) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos5422 HW Modem: XMM6360 Security patch level: 2016-10-01 Codename: k3gxx Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Exploit has been executed successfully Phone will restart now. Please don't disconnect cable! Certificate read successfully Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SM-N920K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Selected file: C:\Users\Furqan wali\Desktop\SM-G900H_ 353415064151122_R51F600P1C.cert Detected phone model: SM-G900H Firmware compiled date: Thu Oct 20 22:02:36 KST 2016 PDA version: G900HXXS1CPJ9 CSC version: G900HOJV1CPF1 SW version: G900HXXU1CPCA Phone SN: R21F4203R2P Android version: 6.0.1 (MMB29K) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos5422 HW Modem: XMM6360 Security patch level: 2016-10-01 Codename: k3gxx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully New security detected Checking for compatible Certificate and phone... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.4.7 Software version. Thanks cert read & write done |
