10-25-2015, 04:41 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2188261 Status: Offline Thanks Meter: 13 | G900P Domestic Unlock not working ----------------------------------------------------------------------------------- To connect SM-G900P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#3424#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G900P Mode: Normal Phone model: SM-G900P Firmware compiled date: Aug 05 2014 Firmware compiled time: G900P.04 Firmware released date: Jul 30 2015 Firmware released time: 14:48:13 Phone IMEI: ******-**-******-* SW version: MPSS.DI.2.0.1.c2-00082-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G900P ADB server killed. Detected phone model: SM-G900P Firmware compiled date: Thu Jul 30 15:39:53 KST 2015 PDA version: G900PVPU3BOG1 CSC version: G900PSPT3BOG1 SW version: G900PVPU3BOG1 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 5.0 (LRX21T) Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. I removed imei from the copy paste. |
10-25-2015, 06:10 | #2 (permalink) |
Insane Poster Join Date: Jul 2015
Member: 2425271 Status: Offline Thanks Meter: 4 | dial *#0011# Press Menu and select "Back"<from the menu that comes up not the phones back button Press Menu and select "Key Input" enter value Q <- capital Q not lowercase q Press Menu and select "Key Input" enter value 0000 <- 4 zeros Wait 10-15 seconds for it to return you to its main screen. then do this UE Setting & Info > Setting > Protocol > GCF > Select the top option in GCF [1] It will say "success". |
10-26-2015, 10:40 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please try to do the next: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". Wait for 20 seconds and a menu will pop up. Perform the following actions in menu: 1. Press UMTS. 2. Press DEBUG SCREEN. 3. Press PHONE CONTROL. 4. Press NETWORK CONTROL. 5. Press GCF, then the top option. 6. Press phone's "Home" button. 7. Go to Settings and change the Mobile Networks to Automatic, or GSM. |
10-27-2015, 02:11 | #5 (permalink) | |
Member: 2188261 Status: Offline Thanks Meter: 13 | Quote:
10-27-2015, 12:29 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload *.log and *.logx files of "Domestic Unlock" operation and post here download link. We will check where can be the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
10-27-2015, 19:05 | #9 (permalink) |
Member: 2425271 Status: Offline Thanks Meter: 4 | Even though the phone said invalid simcard after unlocking, everything will be solved after gcf configuration. plese do the reset after the configuration. then it will get the signal right away and disappear the invalid simcard. |
10-29-2015, 10:50 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please contact us to Skype, or Yahoo! messenger, we will try to help You. Our contacts You can find in our profile. |
